Author Topic: Heater rheostat  (Read 4765 times)
Re: Heater rheostat
« Reply #15 on: 03 October 2013, 18:08:59 »
I wonder if theres any way of testing the hedgehog ?  :-\
Guess there must be but I don't know it
Reply #1 http://www.omegaowners.com/forum/index.php?topic=111222.0  ::) ::)
combatzone
  • Northern Ireland
    • 3.0 mv6
Re: Heater rheostat
« Reply #16 on: 03 October 2013, 19:13:54 »
Is there a handy way of by-passing the hedgehog to see if it is faulty?
My electrical knowledge is very limited, forgot to mention that the fan doesn't work at any speed at all if that would effect the cause.
thanks
Neil
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: Heater rheostat
« Reply #17 on: 03 October 2013, 19:17:40 »
I recall on the Senator there was some sort of electronic device (a diode?) in with the resistors in the heater fan control unit, and it was this device that ofter failed. A replacement from radiospares was the cure.
Re: Heater rheostat
« Reply #18 on: 03 October 2013, 19:20:56 »
thanks
Neil
Click on the link in my previous reply
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: Heater rheostat
« Reply #19 on: 03 October 2013, 19:24:57 »
thanks
Neil
 ;D ;D ;D ;D :y
combatzone
  • Northern Ireland
    • 3.0 mv6
Re: Heater rheostat
« Reply #20 on: 03 October 2013, 19:35:00 »
thanks
Neil
Sorry didn't see that there. Thanks will get to it here :)
Re: Heater rheostat
« Reply #21 on: 03 October 2013, 19:36:02 »
Did I say that?  Must be getting a touch of the Albseimers ???  At least you got a mention though Rob ;) ;) ;)
combatzone
  • Northern Ireland
    • 3.0 mv6
Re: Heater rheostat
« Reply #22 on: 03 October 2013, 20:00:49 »
Read the description on how to test the hedgehog. However when I removed the connector from the hedgehog I could only larger connectors are the two that go to the fan, one being a + and then other a -. The other connector on the hedgehog has four pins on it all the same size. So which two do I join together?
Thanks
Neil
Re: Heater rheostat
« Reply #23 on: 03 October 2013, 21:23:15 »
Thanks
Neil
Shackeng
  • Ramsbury
Re: Heater rheostat
« Reply #24 on: 04 October 2013, 23:12:41 »
Thanks
Neil
Ooh you are cruel. ;) ;) ;)
