Author Topic: Welding manifold?  (Read 4083 times)
Re: Welding manifold?
« Reply #15 on: 05 October 2013, 13:06:50 »
No expert but i thought the crack had to be ground into a V for the weld  :-\
Ideally yes, you get better penetration that way, but on something like the outside of a manifold it's perfectly acceptable to build the weld up & leave it. A weld prep is needed in places where you'd need to grind the weld back flush again eg on the mating face of the manifold where it bolts to the head.
« Reply #16 on: 05 October 2013, 13:58:34 »
I'd give the High Heat Adhesive a go as it'll be quick, easy and cheap!  :y
As Mark has pointed out it only needs to be gas tight and it's been used and recommended by Symes!!  :y
mrgreen
  • Salzburg/austria
    • 2000 2.2 petrol estate
« Reply #17 on: 06 October 2013, 08:30:42 »
I'm going to try that adhesive as mine has a crack and although i've got another manifold for it i am too scared of shearing off bolts to replace it!!
Warning: Dates in Calendar are closer than they appear.
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #18 on: 06 October 2013, 12:05:31 »
So do the 2.2 manifolds seem to all crack in the same place  :-\
« Reply #19 on: 06 October 2013, 19:08:57 »
If welding it then you need a U prep rather than a V.
For both welding and any other repair method, a small hole should be drilled first at both ends of the crack to stop the crack propagating in the future (a hole has no corners and hence no points where a stress riser can form)
« Reply #20 on: 06 October 2013, 21:08:31 »
2.0 crack as well . Normally in the middle top or bottom .
