Author Topic: Combi Boiler Problem  (Read 3055 times)
« on: 27 May 2008, 22:09:16 »
Pressure is low - 0.2 bar
Hot water is fine - central heating won't work. low pressure light is on.
Other, maybe related symptom, arrived home from 2 days away to find all 3 gerbils dead, they all had food and water and were healthy prior to departure.
Possible gas leak? Can't smell anything...
I know nothing, so opinions welcome :y
Re: Combi Boiler Problem
« Reply #1 on: 27 May 2008, 22:10:57 »
Doesn't sound good - get an expert to check it out asap :o
« Reply #2 on: 27 May 2008, 22:11:07 »
Call the Gas board NOW :exclamation :exclamation :exclamation
LJay
  • North Wales
  • The Acrobatics Queen!
    • 3.2 - MV6 Big Blue!
« Reply #3 on: 27 May 2008, 22:12:55 »
sounds suspiciously like carbon monoxide issue. would maybe switch off and call in an expert!
what a crap week your having James :(
Been there, fallen over it!
« Reply #4 on: 27 May 2008, 22:14:15 »
remember carbon monoxide has no smell....   ...if you are not 100% confident in a repair, and it sounds like you're not, switch it off and get the experts in...
« Reply #5 on: 27 May 2008, 22:14:40 »
Is there any sign of water leakage?
The pressure is the water pressure, so not related to the gas side. There should be a filling loop somewhere - basically a flexible pipe with a valve at each end which connects the heating system to the mains water for filling purposes.
To correct the low pressure, open the valves on the filling loop, allow the pressure to reach the normal operating pressure (typically 1.5 - 2 BAR - is there a red marker pointer on the pressure gauge?) then close the valves and see if it works.
Sorry about the gerbils :'( I can't really see how it could be related but might be worth making sure the place is well ventilated when using the boiler and getting a carbon monoxide alarm.
Martin_1962
« Reply #6 on: 27 May 2008, 22:16:32 »
Dead gerbils are the worry, are you up for a fiddle first?
Take off the cover and check for soot. See if any foreign objects in there.
If not - call an engineer.
Is hot water on an immersion heater?
ANy water leaks
Has a radiator popped.
« Reply #7 on: 27 May 2008, 22:16:44 »
Could not agree more.
Like brakes on a car, boilers & gas is not one area to penny pinch.
I know you have work problems at the moment, but you must get this looked at.
Get someone you can trust in, get references!
Do you have british gas home plan thingy? If not still try and get them in, they won't be cheap, but we have found them excellent in our experiance.
waspy
« Reply #8 on: 27 May 2008, 22:16:47 »
James. Don't take any chances bod, it's not worth it  :'( :'( :'(
« Reply #9 on: 27 May 2008, 22:18:57 »
I'm not suggesting we will take chances - if there's a prob, it will be looked at by experts - ;)
    • 530D M Sport, 330i Coupe
« Reply #10 on: 27 May 2008, 22:19:05 »
Agreed, used to have that problem when I had a weeping radiator, once the water pressure in the radiator loop system drops the boiler will not switch over.
« Last Edit: 27 May 2008, 22:22:14 by VXL_V6 »
« Reply #11 on: 27 May 2008, 22:19:50 »
Agree the low pressure is not gas related, but 3 dead gerbils highlights an issue somewhere.
A CO detector is a good idea
Martin_1962
« Reply #12 on: 27 May 2008, 22:23:45 »
What bothers me is both CO and low pressure at same time.
Combis are usually sealed and should not leak into the house.
Water - has to be a leak somewhere could be as simple as a loose bleed valve.
What I am suggesting is look for the obvious first, before an engineer.
« Reply #13 on: 27 May 2008, 22:33:00 »
Agreed - but you can put some water pressure in there and see if anything obvious happens. A bit of diagnosis and going armed with a few ideas will save you a fortune when you get someone in - because if you appear clueless they will spend ages doing unrelated stuff at 50 quid per half hour. Just like when you take your car to a main dealer. Been there, done that. >:(
Look for signs of leakage. Anything under the boiler or any of the rads? Next, there should be a pressure relief valve that discharges excess pressure outside the house. Go and look at the outlet and see if it's got wet.
Then put a bit of pressure in the system and see if there's leakage from somewhere. Could be a number of issues:
Catastrophic failure of the heat exchanger in the boiler - odd that it works on hot water though.
Leakage from a rad or something else in the system.
Leakage from the pressure relief valve
Failure of the boiler thermostat so the water has boiled, overpressurised and forced its' way out of the relief valve.
Is the boiler a room sealed type with a fan assised flue? If so, the boiler should be contained in a sealed box that can't let CO out into the house. There would have to be obvious leakage or damage to the case  for this to happen.
If it's not room sealed, it relies on airflow through the flue or up the chimney by convection, and a blockage could cause it to vent into the room. In this case, get a technician in to check the flue. They will normally do this by lighting a pellet of smoke generating material by the burner and making sure the flue carries it all away outside the house.
Just a few pointers, so when you get told the equivalent of "head gasket, mate" you are pre-armed!
As others have said, CO is deadly, so don't run the boiler without ventilating the place or when anyone's asleep until it has been checked.
Nickbat
« Reply #14 on: 27 May 2008, 22:39:31 »
James,
PM Boiler Man. He was last online on 21st May, but I'm not sure he visits that often.
However, this is very disturbing. It may be nothing, but you have to accept the possibility that the gerbils succumbed to CO poisoning. My strong advice is DO NOT USE the boiler at all until it has been checked. In the meantime, use a kettle for hot water. Remember that CO is completely odourless and the only warning of impending poisoning (and death) is feeling sleepy/lethargic.
I would not underestimate the potential seriousness of this fault.
Nick
