Author Topic: WANTED: Rear Spring Pads  (Read 2145 times)
« on: 04 October 2013, 15:05:36 »
As per the title please. I'm looking for a set of 4 Rear spring rubber seating pads please. Preferably from an estate but saloon would probably do :y
Thanks
omegod
  • liverpool
    • 2017 Seat Ateca
Re: WANTED: Rear Spring Pads
« Reply #1 on: 04 October 2013, 18:21:27 »
Def got some on mine, can the rear springs be removed without compressors?
« Reply #2 on: 04 October 2013, 18:52:03 »
Yes. Iirc theres a guide on here. Not too bad a job ime. :y
amba
  • Medway towns
    • German V6
« Reply #3 on: 04 October 2013, 22:13:27 »
Unbolt the 4 diff mounting bolts and lower it on a trolley jack.If exhaust still in place remove rear box rubbers/disconnect ABS sensors from diff mountings and slacken rigid rear brake pipes and once diff has been lowered the springs can just be removed by hand.
Quite straigth forward and should take only about 30 mins a side.
« Reply #4 on: 05 October 2013, 23:54:31 »
Due to a change of plans I no longer require these... Thanks for the offer
