God I'm annoyed (camshaft refitting with pics)
Started by Webby the Bear, 04 October 2013, 19:01:41
Quote from: Webby the Bear on 04 October 2013, 19:55:10
Quote from: Emd on 04 October 2013, 19:52:51
Bolt should come out easy enough , just take your time dude . I can imagine a few swear words were exchanged between you an miggy  :'(
nah, I don't swear at them anymore. I used to throw tools around  :'( but found a calm place that i'm happy in.
to be fair all I have to do is get the cams in, button up exhaust fannymould on drivers side, cambelt, cam covers and plenum back. the only thing I think im going to struggle on is the electrical connections i.e. where they all go  ;D
Start at the ECU and you won't go far wrong :y
Webby the Bear
Quote from: ex taxi al on 04 October 2013, 19:57:17
will do cheers mate  :y :y :y
RIP Paul Lovejoy
Just remove that cam cap and then tap the remnants of the bolt round until it comes out.
Got some bolts in the garage I think if you need some
Quote from: Fuse18 on 04 October 2013, 20:08:50
Just remove that cam cap and  .......
Go on Mark ...... I'll agree with you  ::) ::)
Webby the Bear
thanks guys... ive got plenty of cam cap bolts thanks  :y
hope it goes easier from tomorrow onwards  ::)
RIP Paul Lovejoy
symes
ask emd-take cam cap off use small screwdriver to chisel bolt around-when enough proud-use pliers---done several-as this happens more than people admit :y oh seal is fine as is-by the way---
Webby the Bear
Quote from: symes on 04 October 2013, 22:02:46
thanks symes youre a star  :y
RIP Paul Lovejoy
Yep , it happened on my engine re build . Change underwear when it happened but the snapped bolt came out pretty easily  :y
Gaffers
That cam seal looks a bit proud too.  It wont go in fully when the front cap is fully torqued (been there, tried it) you'll have to let it off a bit to be able to get it to go in properly.  Once the seal is fully inserted and level, retorque the front cap :y
