Author Topic: overnight battery drain  (Read 1956 times)
takemineanywhere
  • swindon uk
    • 2000 omega2.5td cdx
« on: 06 October 2013, 13:10:45 »
Hi    battery 7 months old goes from 12.8 to 12.2 overnight on my 2.5td.I,ve got a meter on it at the moment & its stabalised at
71 mh....On the neg terminal from the battery theres 3 thick grounding cables,one to alternator BUT WHERE DO THE OTHERS GROUND.
Thought i would check these before i start pulling fuses....any hep very welcome
2000 2.5td cdx        1985 bmwr80rt
grain.ben
Re: overnight battery drain
« Reply #1 on: 06 October 2013, 14:08:07 »
I would be checking the powersounder before anything, if yours is still in there  ;)
takemineanywhere
  • swindon uk
« Reply #2 on: 06 October 2013, 15:37:42 »
took that out last year.No current at the plug that used to connect to it.
Just had look at rear fag lighter relay.2 connector plugs just dangling.Seems a PO been doing something.Which fuse do i pull to disable this as it never gets used?   cheers
grain.ben
« Reply #3 on: 06 October 2013, 18:33:53 »
http://www.omegaowners.com/forum/index.php?topic=90451.msg1155234#msg1155234
fuse 27 - 20amp on a facelift iirc
But, fuse 27 also does the self levelling suspension iirc  :-\
« Last Edit: 06 October 2013, 18:35:57 by grain.ben »
