Author Topic: OK, own up.. which one of you Omega owners was this?  (Read 5040 times)
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
Re: OK, own up.. which one of you Omega owners was this?
« Reply #15 on: 11 October 2013, 16:08:57 »
4 wheel drive
« Reply #16 on: 11 October 2013, 16:21:47 »
 :y Thought it was ::) would have thought they would have worn more...
Is it full time or adaptive :-\
« Reply #17 on: 11 October 2013, 16:42:48 »
I thought it was advisable to change all 4 tyres with 4 wheel drive cars....  :-\
pscocoa
« Reply #18 on: 11 October 2013, 16:43:02 »
Full time - no option to change
pscocoa
« Reply #19 on: 11 October 2013, 16:43:54 »
Dealer never suggested - I did read this as well but at least they didn't milk it for once
Rog
« Reply #20 on: 11 October 2013, 19:08:21 »
Whew . . . .  no CCTV or pictures   8)
That's a relief . . . . . . .  ::)
« Reply #21 on: 11 October 2013, 20:16:35 »
Even four 19" tyres are cheaper than the transfer box ::)
Have just read this...
http://www.volkswagen.co.uk/technology/transmissions-and-drivetrains/4motion
Which confirmed my suspicions... the system default is to only send 10% of the drive to the rear axle, so in every day driving, the rear tyres are simply keeping the back end up off the road, hence the (lack of) rear tyre wear :y
pscocoa
« Reply #22 on: 11 October 2013, 22:12:20 »
It is slightly different if you go down article to this:
"On the Phaeton, under normal conditions, the Torsen differential shares driving forces equally across front and rear axles. If it detects wheel slip, it instantly diverts as much as 20 per cent of the driving power to the axle with the better traction (max. 70:30, or 30:70). Its locking effect increases automatically along with the load. In contrast to a "speed sensing" viscous lock, it operates in "torque sensing" mode. The advantage is the lack of torsional stress when cornering, as it is designed to allow the differential rotational speeds the car automatically wants to use."
Good overview though - not read before
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #23 on: 11 October 2013, 22:22:32 »
Cocoa, just read your omega thoughts.
I totally agree that the omega can be a pain and ive often thought about letting her go. however, mines been parked up for just over a month and with a little luck she'll be running again over next couple of weeks.
I've missed her so much  :'( :'( :'(
just thought i'd pass on my thoughts to consider before you think about getting rid mate  :y :y :y
RIP Paul Lovejoy
pscocoa
« Reply #24 on: 11 October 2013, 22:35:32 »
It is going for mot on Tuesday - so will see what happens.
Thanks for your thoughts.
bored bigyin54
  • south wales
    • black beast
« Reply #25 on: 12 October 2013, 05:51:28 »
I can't see any self respecting OOFer abandoning his Omega whatever the circumstances!!!  ::)
i did  ;D ;D
« Reply #26 on: 12 October 2013, 09:46:14 »
I can't see any self abusing OOFer abandoning his Omega whatever the circumstances!!!  ::)
i did  ;D ;D
;D
