MOT expiry question
Started by Webby the Bear, 13 October 2013, 13:28:43
As said, no MOT, you have to get it off the road.
Even if SORN'd (thats what the OR bit stands for ;))
Webby the Bear
Thanks TB  :y :y :y
Gonna do some work tonight..... using the torch  ::)
RIP Paul Lovejoy
zirk
Just to add, as said pre booked MOT is a must, make sure when you book it in they have all your details, Pre booked means it has to be driven directly there and local, also technically you only have 1 hour before and after the Test (if it fails or you dont have Tax) for it to be legally driven on the road.  :y,
Quote from: Webby the Bear on 14 October 2013, 17:59:34
Thanks TB  :y :y :y
:o
Brings back memories when the work was being done on mine ...Torch/Umbrella and mucho swearing fitting the cambelt  ::) :(
Webby the Bear
Quote from: Emd on 14 October 2013, 19:14:45
Thanks TB  :y :y :y
:o
Well got some stuff done. not much but every little helps. still got a problem with the aux belt tensioner. I fought with it tonight and its still catching the cambelt cover. not sure what to do about it  :-\
RIP Paul Lovejoy
martin42
Have a look in day light,and call it a day for now,come back to it when your not stressing over it and you will find its something simple to sort out :y
Oh what joy it would be to have a garage  :( Hopefully next year a heated one .
Quote from: zirk on 14 October 2013, 18:47:07....
I can't see that ..... what if you dropped it off on your way to work & then wanted to collect it on your way home 8/10/12 hours later  ::) ::)
Quote from: Emd on 14 October 2013, 20:17:12
You'll just fill it with crap ....... like me!  ??? ;D ;D
Quote from: Andy B on 14 October 2013, 20:18:12
Well the shed will be demolished so you got a point  :-\ Forgot to tell me dad he's laying the bricks  ::)
Got to be ready for the gearbox/clutch party in march/april  :)
I thought not having a garage would just be a minor inconvenience. Its not, its a constant headache  :'(
Quote from: TheBoy on 14 October 2013, 20:31:43.....
It would have been if you'd been outside when it blew up!!  ???  ;)  ;)  ;)
martin42
Quote from: Emd on 14 October 2013, 20:28:43
Hopefully have airtools and compressor aswell ready for it.
Quote from: The Mad mechanic on 14 October 2013, 20:34:58
Meant to say there are some compressors going on the bay , dont forget the plasma cutta and mig welder  ;)
