Author Topic: Cam cover Gaskets.  (Read 3201 times)
Jusme
  • North Hykeham, Lincoln.
    • Lexus LS430
Cam cover Gaskets.
« on: 17 October 2013, 11:45:46 »
I know that ONLY genuine GM gaskets must be fitted, but, do GM make gaskets? Phoned a supplier today who supply cam cover gaskets and O rings made by 'Elring'. Was told that these are genuine Vauxhall gaskets. Before I end up throwing even more money down the drain, can anyone shed any light on this??  :y
Under-steer is when the front of the car hits the wall, and over-steer is when the rear of the car hits the wall.
Power is how fast you hit the wall and torque is how much of the wall you take with you.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Cam cover Gaskets.
« Reply #1 on: 17 October 2013, 12:32:58 »
You can use whatever gaskets you want! It's your car ;)
However experience has shown on here that the genuine are best.
As for the make I dont know. But i've rebuilt the top end of my engine with pretty much all Elring stuff (ironically other than the cam cover gaskets) so i'll report up soon once it's running  :y
RIP Paul Lovejoy
martin42
« Reply #2 on: 17 October 2013, 12:39:42 »
Ive used pattern gaskets and never had a problem,all down to the person fitting them and cleaning out the breathers properly.
Webby the Bear
  • Northampton
« Reply #3 on: 17 October 2013, 12:41:24 »
 :y :y :y
ps, not thread stealing but she'll be done tonight martin, im convinced!  ;D
RIP Paul Lovejoy
« Reply #4 on: 17 October 2013, 12:45:05 »
Really poor advice, over the years time and again OOF has proved pattern gaskets are hit and miss. Even with clean breathers, right sealant fitted well. They still leak.
Pattern gaskets has turned into a stupid joke recently, but the aim has always to be most cost effective repair for best value for money.
Hence OOFs recommendation is always genuine.
martin42
« Reply #5 on: 17 October 2013, 13:17:20 »
Not everybody can afford genuine parts,i have said in the past i use pattern parts,with results,my cabby is,still leak free after 10 months use,and that was a £3 gasket,at the end of the,day its the op's car,and what he,can afford to buy.
« Reply #6 on: 17 October 2013, 13:17:28 »
Yep, in the early days I tried numerous different brands of gasket including FAI, Ebay cheap shite and Elring, but of course, as per the Mad Mechanic, my labour quality is clearly substandard  ;D
THE only reliable gasket that worked was the GM sourced ones.
Elring do make gaskets for GM but they dont make the cam cover ones.....
« Last Edit: 17 October 2013, 13:31:16 by Fuse18 »
Jusme
    • Lexus LS430
« Reply #7 on: 17 October 2013, 13:28:01 »
Thanks for replies. Eventually sourced a pair packaged, genuine GM for £35 inc postage. (been on the shelf awhile??) Plus 16 O rings for £1.60 postage £5.89. Total £7.49. Went the whole hog and ordered a Bosch 2.4.6. coil pack @ £62.53 inc VAT + postage £6.15. O rings from Vauxhall dealer 84p each. Gaskets £65:16..  :y
« Reply #8 on: 17 October 2013, 13:30:31 »
1) As keep saying, cost effective. Buy pattern buy twice, more expensive and time consuming in long run.
2) You offering advice based on gaskets not even for an Omega then!
Where is a brick wall, I need to hit my head against it  ::)
« Reply #9 on: 17 October 2013, 13:31:03 »
Good stuff. Make sure you get the correct sealant too  :y
Jusme
    • Lexus LS430
« Reply #10 on: 17 October 2013, 13:33:50 »
Not everybody can afford genuine parts,i have said in the past i use pattern parts, Some of you will already know that I have thrown £3,000 at this darned motor in the last 12 months. (me stooopid.) Thanks to a mechanic (ex mate) not doing the job properly. Need the proper bits, but money is tight...  :( Thanks for that Tunnie. Yes I think Daz has the right sealant....  ;) :y
martin42
« Reply #11 on: 17 October 2013, 13:34:26 »
I did own a 2.6 mv6 and used pattern cam,cover gaskets so yes i am going on my own experience as a previous omega owner and if and when i do get another omega i shall use pattern cam cover gaskets  :y
« Reply #12 on: 17 October 2013, 13:39:30 »
Each to their own, just stop with your poor advice on them then. Some people want a solution that lasts.  :y
Jusme
    • Lexus LS430
« Reply #13 on: 17 October 2013, 13:40:55 »
I have to bow to experience on this matter, and cannot really get embroiled in a genuine v pattern argument. But perhaps the bloke who last did my engine didn't do a great job fitting the gaskets?? Only he knows??  :-\
« Reply #14 on: 17 October 2013, 13:42:05 »
Dont get ralf started  ;D
