Author Topic: GRV  (Read 2523 times)
pirate
  • westhumble surrey
    • steinmetz elit estate
GRV
« on: 17 October 2013, 19:57:19 »
gas rec valve, mine started a fluttering leak by bottom plate if i remove and blank  as ive done on other motors will this sort or do i need a new one,of course i shall leave wiring connected.
due to new beasty the steinmetz omega will be up for sale shortly.
Re: GRV
« Reply #1 on: 17 October 2013, 20:11:08 »
Give us a clue on the engine  ::)
Re: GRV
« Reply #2 on: 17 October 2013, 20:29:28 »
Assume you mean egr - if V6 blank it off but leave wiring connected ;)
Re: GRV
« Reply #3 on: 17 October 2013, 21:30:14 »
If petrol, blank it, but leave the unit in place, as the ECU looks at a position sensor inside.
If a TD, you can blank, but I'd clean it up and try to restore it.
Not sure about DTi
Re: GRV
« Reply #4 on: 17 October 2013, 21:30:43 »
And its called an EGR - Exhaust Gas Recirc :y
pirate
  • westhumble surrey
Re: GRV
« Reply #5 on: 17 October 2013, 22:00:03 »
ha ha yep egr im tired just replaced front disc,s and pads as slowing from autobhan speeds sure does wear the fook out of them.
thought as much will mill a blank tommorow and fit,yep modified 2.5 v6 .
pirate
  • westhumble surrey
Re: GRV
« Reply #6 on: 19 October 2013, 20:55:51 »
blimey wouldnt have thought blanking egr would make eny noticable difference but it sure has, must have been leaking passed more than i thought.and no vibration from front end much smoother passed 100 mph.
who me officer :y
