Author Topic: Doing front polybushes on the car..  (Read 7679 times)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Doing front polybushes on the car..
« Reply #15 on: 18 October 2013, 21:09:38 »
You could use a jig-saw.or if got a compressor, air saw. :)
Hoof'land storeman.
chrisgixer
« Reply #16 on: 18 October 2013, 21:10:02 »
I found it a pain to cut in-situ, but your eyes are probably better than mine. I decided to remove the wishbone for the other side. As said, be careful not to cut into the wishbone.
I think Chris must be younger than me. My joints wouldn't survive a morning crouched in the wheelarch sawing out the bushes :(
He has a pit.
I jack the car onto ramps.
Correction, I jack the front wheels onto ramps.
Bah, you know what I mean. :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #18 on: 18 October 2013, 21:31:07 »
Having replaced bushes on other cars, I'd need a bloody good reason to even consider trying it with the wishbone on the car! All the descriptions of how it's done reinforces that opinion. After all, it's only two more bolts, and it means you can evaluate the rear bush and the balljoint. As for doing it with the car on the ground, you must all be mad!
chrisgixer
« Reply #19 on: 18 October 2013, 21:33:09 »
Don't knock it 'til you've tried it. Or seen it. Its easy. ;)
chrisgixer
« Reply #20 on: 18 October 2013, 21:34:04 »
(Video won't play for me btw ;) )
  • Chatham, Kent
« Reply #21 on: 18 October 2013, 21:51:36 »
Poly wishbone bushes on mine. Plus the anti-rollbar ones(I wouldn't bother with them again). Replaced the rear bushes and balljoints while I was at it. There is no way I'd do any of this with the wishbone on the car.
« Reply #22 on: 18 October 2013, 22:04:43 »
Works ok here ;)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #23 on: 18 October 2013, 22:10:42 »
Did the TD this year, no problem, I'm 76. :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #24 on: 19 October 2013, 01:37:43 »
chrisgixer
« Reply #25 on: 19 October 2013, 04:07:09 »
Each to their own. But obviously I was referring to the process of fitting poly with the wishbones on the car. You can't really knock it, until you've tried it. It really is very doable. A one or two spanner job, in Haynes parlance. Especially for someone as handy with spanners such as yourself.
Also, obviously, if the rearward vertical bush is buggered its a bit pointless. May as well remove the wb's.
Don't want to be picky on a very helpful video, but to save some possible unnecessary agro...
Turks video mentions undoing the rearward bush bolt, there is no need to undo that rearward bolt.
« Reply #26 on: 19 October 2013, 06:26:18 »
The other mahoosive plus for changing them on the car is that you don't then need a full geometry set up :y
« Reply #27 on: 19 October 2013, 09:51:54 »
No real issue with doing it on car - the slight inconvenience of perhaps not being the best working environment is not enough to warrant the extra hassle of WB removal (that I find a real PITA).
The hard part is cutting the old one out - its slow and fiddly, this is the bit that will take the 30-60 mins per side. As Gixer says, don't quite cut through, then use a small cold chisel right by the cut to peel it up.
Seth
« Reply #28 on: 19 October 2013, 10:34:49 »
I know, I know ... gonna drag 'im in the office 'bout that ... when I can actually find the git boyo! ::)
