Author Topic: Insignia Auto boxes  (Read 14131 times)
Re: Insignia Auto boxes
« Reply #30 on: 20 October 2013, 14:05:42 »
The numbers won't be much different on that, probably 50ppm :-\
Tbh, I'm still not convinced by your figures. Depreciation a drop £20k in 4 years? (more like 8-10 years) What you smoking.  ;D On Merc that cost say £23k to begin with  ???  ??? - Looking at £5k Mercs that gets you 10 year old examples with 100k+
Insurance, well, you are way over on that  ;D
Along with vast over estimating on tyres & brakes, I think actual ppm will be much, much lower.
« Last Edit: 20 October 2013, 14:08:28 by tunnie »
« Reply #31 on: 20 October 2013, 14:29:05 »
I'm also staggered you think it would cost:
Brakes, discs and pads every 40k/annually £800
 ;D ;D ;D
I don't think I've spent that combined in life time of all our Omega's on brakes  ;D
Quick search found this chap who paid £82 for each front disc from a Main Merc dealer on CL600  :o
http://www.mbclub.co.uk/forums/general-discussion/151054-main-dealer-not-so-bad-after-all.html
« Reply #32 on: 20 October 2013, 14:37:00 »
Depreciation is affected more by mileage than age, I assumed a trade in value after 4 years of £4k. So if the screen price is £24k, and the final value is £4k, that is a loss of £20000, which over 4 years is £5k per year ::)
I also assumed 40k miles per year, so after 4 years, that's 160k. If the annual mileage is higher, then the worse the depreciation gets.
At that mileage insurance, tax, servicing and tyres come to a whopping 7.5ppm, easily the smallest cost of the car.
Finance 18ppm
Fuel 15ppm
Depreciation 12.5ppm
Ins/tax/maintenance 7.5ppm
Regarding your 600CL example, I bet he didn't pay them to fit them though ::)
Anyway, I said I assumed alot, put in the actual dealer figures, based on the expected annual mileage and see what comes out. Until you actually run a particular car, you won't know what the brake or tyre wear rates will be, so overestimating is actually good practice...
« Reply #33 on: 20 October 2013, 14:37:56 »
Did I mention that I made alot of assumptions  ::)
The figures work, based on those assumptions :y
« Reply #34 on: 20 October 2013, 14:43:10 »
No finance, so that ppm is irrelevant.  :y
Your depreciation is still way off, find me a 2009 Plate E-Class for £4k!!!
http://www.autotrader.co.uk/search/used/cars/mercedes-benz/e_class/postcode/w39ej/radius/1500/sort/default/maximum-mileage/over_100000_miles/maximum-age/up_to_4_years_old/onesearchad/used%2Cnearlynew%2Cnew
I'll save you some time, you won't you need around £10k  :y
Huge numbers of examples there, ranging from 120k to 180k miles, around 4 years old, 2009 ish plated for £10k.
« Reply #36 on: 20 October 2013, 14:53:32 »
Doing few more searches, those E Class Coupe's look fairly new, plenty of 2009 100K+ examples still going for around £12-15k.
So getting one at say £23k with 20k on the clock, keeping for 3 years, up to ~100k, easily get £10k back  :y
« Reply #37 on: 20 October 2013, 15:05:23 »
Time will tell, but they're called assumptions for a reason ::)
« Reply #38 on: 20 October 2013, 15:08:45 »
Totally get what you are saying, but think you are vastly over estimating on most things  :y
At least for us, maybe you can get through £800's worth of brakes in 40k miles, but FatherT is a little lighter on the pedals  :y
joshwyatt
  • Oxford
« Reply #39 on: 20 October 2013, 15:18:49 »
Volvo S80 D5 is the only sensible solution. 215bhp, all the toys you'd ever need and much more affordable compared to the E-Class. Residual's are not as good, but you're paying considerably less for the vehicle. Volvo's in general do high miles well  :y
What precisely is FatherT's requirements?
« Reply #40 on: 20 October 2013, 15:21:30 »
Not considered one of those Josh, thanks for heads up.
Requirements are excellent mpg, 30mpg from the Omega is just not good enough. Needs to be around 50mpg ideally  :y
Automatic is a must, along with HID's & i think parking sensors & cruise control. Built in Sat Nav would be very high on the list too, much better than a portable unit.
« Reply #41 on: 20 October 2013, 15:22:07 »
I think if I was forced to look a replacement & my millage was low enough, I'd consider a Classic Merc such as:
http://www.carandclassic.co.uk/car/C382214
« Reply #42 on: 20 October 2013, 15:26:29 »
« Reply #43 on: 20 October 2013, 15:28:08 »
Bit dull inside though  :-\
You got anything interesting in stock at the moment Josh?
joshwyatt
  • Oxford
« Reply #44 on: 20 October 2013, 16:10:03 »
Sadly, everything I have currently could only dream of 30mpg, let alone 50+  ;D
That particular S80 does look dull, you'd ideally want the SE Lux version which has all the toys...but still the interior is restrained...they do look much better with a lighter interior.
We can always take a trip to auction, or give me a brief and I can try and find something?
