Pages: 1 [2] 3  All   Go Down
Author Topic: Come back on dodgy car purchase...  (Read 5201 times)
Re: Come back on dodgy car purchase...
« Reply #15 on: 27 May 2008, 20:38:49 »
Anyone with a K series (esp the 1.4 and 1.8 variants - oddly 1.6 appears better for some reason) will be used to HG failures.
Mrs TheBoy's HG was done by JamesV6CDX and I last year, we went overboard, doing cambelt kit, pump, stats etc etc whilst we had it stripped down (it had down 72k), cost just under £300 for all the bits (later Ks as fitted to Rover 25s seem to have more expensive parts :()
The 2.5 KV6 is good though, dont you think Jaime? ;)
Sadly, double the chance of failure ;)
STMO123
« Reply #16 on: 27 May 2008, 20:39:11 »
KV6 -  >:( mine lasted 8 weeks
Mine sang beautifully for seven years..I traded it last week. Rub of the green :-/
hotel21
  • The Kingdom of Fife
« Reply #17 on: 27 May 2008, 21:52:21 »
A car for sale on a forecourt, technically, requires to be completely road legal.  Not sufficient to sat that a bald tyre will be changed on sale or whatever required for MOT pass will be done....
Sadly, state of the engine does not come into that equation....
« Reply #18 on: 27 May 2008, 22:08:43 »
I've not seen the car, he took it to a friend of his who wanted £550 to replace head gasket, car only worth about £600 tops so not worth it on those numbers...
So, you could scrap it and go and spend the 600 quid on another one which may have a host of unknown problems, or you could fix it (could be done for less than that by a long way) and you've got the confidence that at least the engine won't give you any more trouble for another 100k (the 1.4 isn't as bad as the larger K's).
There comes a time when it makes no sense to sink more money into a car, but if this were the only serious problem, I'd be fixing it. Any car for 600 quid will need a bit of TLC.
theowletman
  • Chester-le-street, Co. Durham
  • Mines a pint !
« Reply #19 on: 28 May 2008, 13:08:32 »
Dont you get a 3 month warranty if bought from a dealer?
As a dealer I can say that the only warranty worth having is the manufacturers own when the car is new, even these are subject to all sorts of conditions. Dan did not say how old the car is, I am guessing at a 1999 T reg or around then, that makes the car 9 years old. What can you reasonably expect from a product of that age? It ran for 6 weeks so the dealer could not have known that it would fail. On cars over 8 years old, or over 100,000 miles or which cost less than £1200 we give no mechanical warranty at all, however the car must be roadworthy and comply with the MOT regulations. At that sort of money you pays your money and takes your chances. The aftermarket 3 month warranties are not usually worth the paper they are printed on, in fact they are no longer called warranties, they are now Mechanical Breakdown Insurances. To make a successful claim on one of these takes some doing. My advice would be to get the job done as the car is worthless if it is not running, get some use out of it and get rid of it.
GinoGinelli
  • London
« Reply #20 on: 28 May 2008, 14:27:48 »
The K series engine in all it's guises is prone to CHG failure .
I believe the early 1.4 k's (square shape cars) are wet rather than damp linered (if I remember what my mechanic was blabbing on about!) and aren't anywhere near so prone. We've got a k-reg on 125k with its original *touch wood!* HG but my dad had a 2001 25 which suffered 2 HGF's; the first at 35k!
« Last Edit: 28 May 2008, 14:28:44 by GinoGinelli »
ryansomega
  • coalville
« Reply #21 on: 28 May 2008, 16:34:44 »
all motor traders have to comply with trading standards which say they have to provide a warrenty with any car that is bought and sold through them.
« Reply #22 on: 28 May 2008, 16:51:45 »
So if I buy a fiesta from a dealer for £100, have I got valid recourse if two weeks later it throws a conrod through the block?
« Reply #23 on: 28 May 2008, 17:59:38 »
.. and they do. Happened to Mrs. KW. ::)
No breather is big enough to stop a HCS turning its' oil manky and self-destructing.
hotel21
« Reply #24 on: 28 May 2008, 19:19:22 »
By 'providing' I think (but not 100%) that means that one is available at extra cost.  If you decide not to purchase one, you don't have one.  If it then throws a conrod, buy a brush and shovel and a large bag of cat litter......
Pete Elite
  • Uxbridge, Middlesex
« Reply #25 on: 28 May 2008, 20:07:53 »
 £550 :o lucky he didn't take it to someone who doesn't much care for him.
« Reply #26 on: 28 May 2008, 21:13:20 »
I'll echo the other comments here. The k series hg failing is common, but a really easy job! They were bread and butter money in the garage where i worked!
Change the thermostat at the same time just in case.  :y
theowletman
  • Mines a pint !
« Reply #27 on: 28 May 2008, 21:30:04 »
The word is reasonable. Most trading standards people are reasonable themselves, we have had 1 visit in 8 years, and that was to see if we were still trading. If you bought a 9 year old kettle would you expect a warranty? If you bought a second hand double glazed window unit for £100, that had previously been fitted, would you expect a warranty? The answer is of course no. I am not trying to defend those traders out there who deliberately sell faulty goods, but there has to be a limit. As Dan said the car ran for 6 weeks so the trader could not have forseen the problems. If you hired a car for 6 weeks what would it cost? I have been very unlucky with cars, I bought a 2000 Golf from auction 3 weeks ago, 56000 miles, 2 owners, FSH, paid good money, transported it home with the others I bought at a great cost, it is now in another auction as it only had 2 gears out of 5 and no reverse. Even those of us who buy and sell for a living get it wrong sometimes. Even if you are buying new or nearly new problems can still arise. The older or more miles on a car increases the chances of mechanical bother. As long as the trader did not misdescribe the car Dan's pal has very little comeback, probably none at all.
JezInBrum
  • Birmingham
  • Built for comfort not speed
« Reply #28 on: 29 May 2008, 01:28:45 »
From my own experience years ago with a Afrur Daley type cars are bought as seen. Even with a limited warranty they still have the get out of wear & tear. Unfortunately its buyer beware. Even trading standards told me this.
As the others suggested shop about.
Jez
haj
  • Brighton
« Reply #29 on: 29 May 2008, 02:01:00 »
Sold as seen is not a legal loop hole for geting out of refunding or repairing the vehicle by a dealer.
A friend was sold a dodgy motor,had lots of probs.went to the dealer told him of problems,he said hard luck missus "sold as seen".She went to trading standards who recommended a garage to lk it over.The garage would not allw her to drive it.It hadshot brakes ,been shunted up the rear basically it was a death trap.TS advised her of the legal process.
She too k out a civil actionshe was told exactly what to do and howto proceed.
Various letters sent to dealer all ignored.
Anyhoo,it ended in court,the dealer actually turned up!!!and he ended up paying court fees and reimbursing the womens money.
So basically sold as seen don't hold s**t and people should not be put off persuing a claim when they are told this.
Pages: 1 [2] 3  All   Go Up
