Author Topic: crank sensor??  (Read 1545 times)
djhorner
  • isle of lewis
    • omega mv6
crank sensor??
« on: 20 October 2013, 20:45:50 »
could a faulty crank sensor stop car starting ?
Re: crank sensor??
« Reply #1 on: 20 October 2013, 20:46:59 »
Yes. The engine will turn over but not fire, easily confirmed with a pedal trick or paperclip test. Sometimes they don't show a 19 code, but normally will.
Replace with genuine only  :y
djhorner
  • isle of lewis
    • omega mv6
Re: crank sensor??
« Reply #2 on: 20 October 2013, 20:49:12 »
rough cost ? as i just rebuilt engine after headgasket failure
Re: crank sensor??
« Reply #3 on: 20 October 2013, 20:51:18 »
as Tunnie said code 19 may not show everytime..  generally it starts to cause problems when engine is hot.. be careful for the cable routing for the new one.
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: crank sensor??
« Reply #4 on: 20 October 2013, 20:57:52 »
£50-60 iirc. As said, genuine only  :y
Cem has just reminded me to tidy up the cabling for my new one  :-X
« Last Edit: 20 October 2013, 21:01:08 by jonny2112 »
djhorner
  • isle of lewis
    • omega mv6
Re: crank sensor??
« Reply #5 on: 20 October 2013, 20:59:25 »
spot on i hope new sensor starts
Re: crank sensor??
« Reply #6 on: 20 October 2013, 22:39:48 »
Worth reading codes anyay :y
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: crank sensor??
« Reply #7 on: 20 October 2013, 23:08:21 »
When my sensor was failing the car still started ok, though I guess there could be different symptoms. Strange that it was starting and running, albeit roughly, before hand.
Definitely codes first, before spending money. Still think there's a plug missing or something you have inadvertently moved when doing the leads.
