Pages: 1 2 [3]  All   Go Down
Author Topic: Head rebuild questions  (Read 3783 times)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Head rebuild questions
« Reply #30 on: 02 November 2013, 09:41:23 »
Valve grinding  :y
get cracking webby 24 valves to lap in, by hand, that keep you bizzy for a couple of minutes  :D
Hoof'land storeman.
symes
  • oxford
    • R reg 940 volvo
« Reply #31 on: 02 November 2013, 10:09:02 »
Valve grinding  :y
get cracking webby 24 valves to lap in, by hand, that keep you bizzy for a couple of minutes days :D
:y :y ;D ;D ;D ;D
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #32 on: 02 November 2013, 10:17:54 »
It is possible, with care, if the design of the head is suitable, to use a hand drill on the stem of the valve, alternately in forward and reverse, at low speed, to make the job easier. If the seats are not too bad, and particularly if using new valves, you can often get away with going with the fine paste straight away. HTH :y
« Reply #33 on: 02 November 2013, 11:01:45 »
I've never used one, I've only ever used a sucker on a stick type, but this might be more suitable for you Webby  :y And as Chris says above, you'll find that it won't take too long to bed a new valve to its seat even with fine paste.
http://www.ebay.co.uk/itm/22-28mm-Valve-Lapping-Grinding-Tool-/181211677567?pt=UK_Hand_Tools_Equipment&hash=item2a310ec37f
Shackeng
  • Ramsbury
« Reply #34 on: 02 November 2013, 11:14:45 »
Excellent idea, they were'nt around when I last did one. :y
Pages: 1 2 [3]  All   Go Up
