Author Topic: spark plugs  (Read 6719 times)
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
spark plugs
« on: 23 October 2013, 23:10:47 »
Are bosch super plus spark plugs ok to use in my 2.6? or is the general thinking to use genuine GM ones
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
Re: spark plugs
« Reply #1 on: 23 October 2013, 23:40:19 »
GM quads are half the price of the Bosch ones :y
But to answer your question, yes they'll be fine :y
Re: spark plugs
« Reply #2 on: 24 October 2013, 03:51:29 »
Gm are the same quality for a fraction of the cost
I'd use twins, not quads, though. We've seen a few instances of quads shedding the (thin) electrical contacts and damaging the head face / bore / internals :y
Re: spark plugs
« Reply #3 on: 24 October 2013, 09:42:31 »
I could say the same about my single experience of twins... failure rate of 1 in 6 :o
Re: spark plugs
« Reply #4 on: 24 October 2013, 10:10:10 »
But we consider it more a forum wide view.  :y
Plus the quads offer no advantage over the cheaper twins and arguably will shield the spark more....all for the sake of longer service intervals (during which time they tend to come loose anyway)
Re: spark plugs
« Reply #5 on: 24 October 2013, 10:12:24 »
Good experience with GM twins here, use them in all 4 Omega's never had a single problem  :y
LPG needs a stronger spark too, mine are overdue an inspection, but all good so far.  :)
tooleater
  • Rickmansworth,  Herts
    • Go faster Black MV6 Man
Re: spark plugs
« Reply #6 on: 24 October 2013, 10:23:15 »
In that case if you buy Gm plugs and part of the plug comes adrift,not so good for your pride and joy :'( who Liable
Re: spark plugs
« Reply #7 on: 24 October 2013, 10:35:08 »
I've got a feeling the GM ones are rebranded Bosch anyway, are they not?
Either way, it's pointless to spend motor factor prices for the Bosch plugs. :o
Re: spark plugs
« Reply #8 on: 24 October 2013, 14:04:17 »
Fair dos :y
My failure coincided with the missfire issues so not as clear a picture as might seem... I change the plugs every 20k any way :y
Re: spark plugs
« Reply #9 on: 24 October 2013, 16:21:29 »
 and arguably will shield the spark more.... ....
I've heard that comment repeatedly .... and still don't see how.  :-\ You can see as much of the relevant parts of the spark plug from end on of a 4 prong plug as you can from a 2 prong plug  ??? ???
Toledodude1973
  • IPSWICH U.K.
Re: spark plugs
« Reply #10 on: 24 October 2013, 18:11:03 »
Thanks for all the replies Jamescdx lookout for an email coming your way if i get a chance tonight
Re: spark plugs
« Reply #11 on: 24 October 2013, 19:50:11 »
Ok mate sure thing :y
dbdb
  • west london
  • Tramlining,Trade Club,WIM,my time racing,Linux etc
    • f/l elite 2.6 V6 manual
Re: spark plugs
« Reply #12 on: 24 October 2013, 23:41:10 »
Quad gaps will last much longer than twins.  Why? Because you have 4  electrodes to erode instead of 2.
If your plugs are coming loose there is something wrong with them or more likely the way they are fitted.  There is no especial vibration on a plug,  if torqued to 25Nn and they are coming loose I would expect a lot of other bolts to be coming off your car too - Coolant pump bolts, Crankcase breather tube bolts, Crankshaft pulley bolts, Crankshaft sensor rotor bolts to name just 4 at the same or less torque.
Re: spark plugs
« Reply #13 on: 24 October 2013, 23:45:16 »
What's the point in longer life? Might as well replace at 20k. Cheaper to buy too.
I've torqued spark plugs to correct value, yet on inspection are looser than fitting.
Only reason GM specify quads is to please fleet managers, along with stupid 20k oil changes. For "cheaper"  fleet management.
« Last Edit: 24 October 2013, 23:46:54 by tunnie »
chrisgixer
Re: spark plugs
« Reply #14 on: 24 October 2013, 23:46:04 »
Look out, the Jedi is on ::)
Knows everything....  :-X
