Author Topic: DVB-T aerial advice.  (Read 4856 times)
« on: 26 October 2013, 17:23:19 »
Looking for a suitable Shark fin type aerial.
Found this as a starter for 10... http://www.smartauto24.com/car-shark-antenna-for-am-fm-radio-gps-gsm-dvb-t-5-in-1-1744
Looking for comparible recommendations, bearing in mind the following...
My current system consists of all Sony...
XAV-72BT HU
XT-DTV1 DVB/DAB tuner
VCA-130 window mounted DTV antenna
XT-100HD tuner
XA-C30/40 (can't remember which) source selector
CDX-656 disc changer x 3
The Digital reception is woeful locally, and intermittent on the move, have previously tried an alternative window mount aerial to no avail. Thinking roof mounted might obtain a clearer signal.
Radio reception is fair to good, both with and without the HD tuner connected, but being a US unit, the frequency choices are somewhat lacking ::) A european version of the HU could resolve that issue, but decent DAB reception would render that problem irrelevant... I can also stream internet radio from my phone to the head unit.
I would prefer Plug and Play, and prepared to pay a reasonable amount for something that provides at least
DVB, DAB and analogue signals, GPS/GPRS capability are a plus :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: DVB-T aerial advice.
« Reply #1 on: 26 October 2013, 17:49:49 »
XAV-72BT HU
XT-100HD tuner
IMHO unless you live very close to a Transmitter or within a known good DVB Signal Area, its all a bit of a non starter trying to use DVB whilst on the move in the car.
Might be better off using TVcatchup.com on 3g or HSDPA somehow.
« Reply #2 on: 26 October 2013, 17:53:30 »
Streaming from the phone is audio only :-\
zirk
  • Epping Forest
« Reply #3 on: 26 October 2013, 17:59:59 »
Why is that then?
« Reply #4 on: 26 October 2013, 18:20:19 »
Yep, DVB is a non-starter while actually moving. The transmission standard simply can't cope with the amount of multipath fading you get on the move.
Bearing in mind that a house antenna is up about 30' off the ground and has a gain of 10-15db or more, and that's the benchmark by which network coverage is planned, you are always going to be fighting a losing battle with a very low gain antenna in a car.
« Reply #5 on: 26 October 2013, 18:49:23 »
Surely the DAB signal would be improved with a roof mounted aerial rather than one mounted inside the rear windows :-\
The tuner is mobile rather than portable, which implies a certain level of moving ::)
Why is that then?
I have to stream via Bluetooth as the HU won't recognise a USB connection to my phone, (still charges it though).
Suspect this is because the HU is designed to be crapple friendly... :-X
Newer models of the HU have mirror link, which accepts some Sumsung phones...
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #6 on: 26 October 2013, 19:59:57 »
Why is that then?
It either accepts Android or it doesn't.
If it accepts iOS, you know what to do!  8)
« Reply #7 on: 26 October 2013, 20:02:08 »
Set light to it :-X
 ;D
zirk
  • Epping Forest
« Reply #8 on: 26 October 2013, 20:38:58 »
Any old Nokia's or SE kicking around in the cupboard with RGB or HDMI out?  ;)
« Reply #9 on: 26 October 2013, 20:51:34 »
Phone has a mini hdmi socket on it if that helps :-\ HU has a flying lead with standard USB socket... there's a readily available adaptor lead for it for crapple purposes which also needs a separate RCA video lead...
Just to add, the USB input is perfectly capable of running a n other storage device, such as a memory stick or Arcos type device, struggles with much over 40mb iirc :-\
« Last Edit: 26 October 2013, 21:03:51 by ex taxi al »
« Reply #10 on: 26 October 2013, 21:53:22 »
Yes, it'll be better, of course. Just saying that it's unlikely to be great whatever you do, especially while moving. ;)
Yes, but it's the signal it's trying to receive that is vulnerable rather than the receiver itself. What you're trying to do is akin to trying to play records in a WRC car, i.e. "it might work OK when you're parked" is about the best you can expect IMHO.
« Reply #11 on: 26 October 2013, 22:00:19 »
 :y that makes sense, the tuner doing what it can with the signal it receives...
  • Auckland
    • Mazda MPV
« Reply #12 on: 26 October 2013, 23:10:52 »
OP's question was about DVB (digital video) I agree that it will be a 'challenge' to hang on to a DVB signal on the move as it was never designed to work with low gain omnidirectional receiving aerials.
DAB (digital audio) was and is intended for mobile use. I get excellent reception with a roof mounted aerial in my Omega.
« Reply #13 on: 26 October 2013, 23:30:51 »
Sorry - didn't spot the shift from DVB-T to DAB.  ::)
« Reply #14 on: 27 October 2013, 00:17:38 »
Not so much a shift :y same unit for both :y
