Author Topic: Ign barrel  (Read 8893 times)
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Ign barrel
« Reply #30 on: 29 October 2013, 21:00:11 »
Good call, does my pfl have a glovebox lock, if so I've never used it, but it should be original, I bought the car at 5k 14 years ago. :y :y :y
It will  :y
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: Ign barrel
« Reply #31 on: 29 October 2013, 21:02:26 »
 :y :y :y
Re: Ign barrel
« Reply #32 on: 29 October 2013, 22:14:49 »
Just file the extra off
Shackeng
  • Ramsbury
Re: Ign barrel
« Reply #33 on: 29 October 2013, 22:36:45 »
An option, but I note that on the upper edges which protrude there are 2 engineered notches on each tumbler, they must be there for a purpose, and would disappear if I file the edges off. :-\ :-\ :-\
Re: Ign barrel
« Reply #34 on: 29 October 2013, 22:40:06 »
just file 'em off till the new tumbles arrive  ;) ;) ;)
(you have pm  ;))
Shackeng
  • Ramsbury
Re: Ign barrel
« Reply #35 on: 29 October 2013, 22:42:30 »
PM received but can't reply due your full inbox. Thanks muchly for the info Andy. :y :y :y
Re: Ign barrel
« Reply #36 on: 29 October 2013, 22:55:37 »
 :-[ Didn't realise  :-[ I'll sort it  :y
Shackeng
  • Ramsbury
Re: Ign barrel
« Reply #37 on: 30 October 2013, 08:39:48 »
Does anyone know what the spring loaded mini door latch just inside the key collar is for? Perhaps to establish the key rotation track against the barrel? :-\ :-\ :-\
Re: Ign barrel
« Reply #38 on: 30 October 2013, 09:10:06 »
That's what you're pressing with the wire/baby allen key to release the barrel.
Re: Ign barrel
« Reply #39 on: 30 October 2013, 09:13:09 »
There there to keep the sides of the tumber away from the side walls of the barrel, losing one wont be an issue.
Shackeng
  • Ramsbury
Re: Ign barrel
« Reply #40 on: 30 October 2013, 09:45:24 »
Thanks Mark, tinkering again this AM, I have reassembled it in working order with the two outer errant tumblers removed, and it appears to work OK. Apart from the - virtually non-existent - security issue, is there any reason it shouldn't be used like this? :y
Shackeng
  • Ramsbury
Re: Ign barrel
« Reply #41 on: 30 October 2013, 09:46:47 »
Surely not Andy, its about 2" away from the release hole.  ??? ??? ???
Re: Ign barrel
« Reply #42 on: 30 October 2013, 09:49:30 »
Nope, still pretty secure as there a ten tumbler lock, its simply now an 8!
Shackeng
  • Ramsbury
Re: Ign barrel
« Reply #43 on: 30 October 2013, 10:02:34 »
That's what I thought, and having discovered what a pita it is to get the glovebox lock out, I'll put it back until the new tumblers ordered (thanks Andy) arrive. :y
It seems reasonable that these two tumblers are the most worn, given they get the most contact with the key. :y
Re: Ign barrel
« Reply #44 on: 30 October 2013, 10:50:16 »
Not sue then, I'd need to have another look inside a lock/barrel  :-\
