Author Topic: supercharger?  (Read 3655 times)
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: supercharger?
« Reply #15 on: 28 October 2013, 21:40:37 »
Only a heavy right foot ;D
We share a common interest!  ;D
In answer to OP.
Supercharging/Turbocharging the V6 will not end well unless you spend a fortune on the Engine.
I've heard good results from LET's in the Omega.  Having said that, I'd prefer torque all through the range rather than a shoddy RR day certificate!  :y
Re: supercharger?
« Reply #16 on: 28 October 2013, 22:14:36 »
if you have plenty of time, good funds , know of good garages with equipment and patience, go for it.. (but not with 2.6)
if you want a quick and easy solution go for a sports car..
Re: supercharger?
« Reply #17 on: 28 October 2013, 22:16:03 »
From what I understand, cooling is the biggest problem. If going to such large expense, why not Supercharge the 3.2? I believe that has a stronger crank
can you explain please.
From my basic understanding, the extra power creates more heat. Which is a problem for pots 5/6, least that's what I read from here. That large amounts of more power, caused cooling issues and it was difficult to cool  :-\
Re: supercharger?
« Reply #18 on: 28 October 2013, 22:31:52 »
If running hot is the problem then surely a better cooling system would be installed , not run the existing rad ect  :-\
Re: supercharger?
« Reply #19 on: 28 October 2013, 23:01:21 »
My understanding was the circulation around the cylinder, so bigger rad would not improve things.
chrisgixer
Re: supercharger?
« Reply #20 on: 28 October 2013, 23:06:04 »
Bottom end bearings are the problem. Cooling system runs double the capacity in an ls1 so the cooling is fine.
ted_one
Re: supercharger?
« Reply #21 on: 29 October 2013, 08:08:46 »
As I say you need to talk to HooverMig as he has done what you are thinking of doing,I have seen the car a couple of times and it's used on road and also track days.He is a very knowledgeable guy and although his car is a pre facelift 2.5 he may well be able to give you some pointers to get you started on your project.....or not, as I really would'nt know wether the 2.6 engine would be the right unit for this type of upgrade. :y
