Author Topic: central locking not resetting.  (Read 1650 times)
jonno1510
  • Kent
    • Omega gls 2.0
« on: 29 October 2013, 11:59:10 »
Hi all this is my first post, so here goes. my central locking was not working , I found a remedy which said . move key to 2nd notch in ignition then press lock on remote fob. All doors locked then unlocked and . Excellent says I. The next day I had to perform this procedure again. It seems to reset fine , but when left over night I have to reset the remote fob. So relay or key fob at fault. Cheers Ps this is a 97 GLS
Re: central locking not resetting.
« Reply #1 on: 29 October 2013, 16:34:59 »
Welcome to the forum.
The battery holder coming loose from the pcb in the fob is known problem ..... sounds like that could be your fault. Dismantle the fob & check the battyer holder.  :y
jonno1510
  • Kent
    • Omega gls 2.0
« Reply #2 on: 29 October 2013, 18:31:46 »
I'll give that a shot, cover is slightly loose. cheers
