Pages: 1 [2] 3  All   Go Down
Author Topic: Desperate  (Read 7783 times)
chrisgixer
Re: Desperate
« Reply #15 on: 02 November 2013, 21:54:48 »
How tight are the wishbone bolts?
danzigfan
  • Jesenice, Slovenia
    • Omega 2.5V6, 3.0V6
Re: Desperate
« Reply #16 on: 02 November 2013, 21:57:35 »
...Tight.... can it be too tight? :-[
« Last Edit: 02 November 2013, 21:59:53 by danzigfan »
chrisgixer
Re: Desperate
« Reply #17 on: 02 November 2013, 22:00:16 »
...Tight.... can it be to tight? :-[
Yes, but we're concerned with them being loose.
How tight, in nm,(of ft lbs) are the bolts?
danzigfan
Re: Desperate
« Reply #18 on: 02 November 2013, 22:03:20 »
Nah..., no nm data there believe me....raw force, eemmm, could it be thread worn out?
danzigfan
Re: Desperate
« Reply #19 on: 02 November 2013, 22:04:39 »
I mean, there was no damage on bolts AFAIK but when 1,7 ton is pressing it, who knows?
chrisgixer
Re: Desperate
« Reply #20 on: 02 November 2013, 22:11:13 »
Ok, if over tight the area around the subframe holes could be damaged, if not tight enough the bolts won't hold the correct position, in either event the wishbones could be moving around.
Is the car stable under breaking? Does the steering wheel twist in your hands?
For info/are you aware, assuming no poly bushes, the bolts need to be tightened to 125nm then angle tightened 35 degrees, then a further 15degrees WITH THE WHEELS LOADED/car at the correct ride height.
chrisgixer
Re: Desperate
« Reply #21 on: 02 November 2013, 22:12:08 »
There are other causes, but given the work done lets start there.
chrisgixer
Re: Desperate
« Reply #22 on: 02 November 2013, 22:13:49 »
And which wishbones where fitted?
danzigfan
Re: Desperate
« Reply #23 on: 02 November 2013, 22:14:41 »
Sooo...there comes first mistake of mine, omega was up when working on it.... no retighting when down
chrisgixer
Re: Desperate
« Reply #24 on: 02 November 2013, 22:19:06 »
If that's the case the front bushes could very well be torn already. Lemforder bushes will take it for a short time, but any rubber bush will tear eventually.
Or, just fit poly bushes. Powerflex.
chrisgixer
Re: Desperate
« Reply #25 on: 02 November 2013, 22:20:00 »
They all tear eventually, bit you know what I mean. Life is reduced to a few months at best.
danzigfan
Re: Desperate
« Reply #26 on: 02 November 2013, 22:20:13 »
And car is stable under braking, I hear and feel banging when driving over small bumps...it just never stops. Just for info - there was no play/banging a day or two after replacing lower suspension arms, before it reappeared
danzigfan
Re: Desperate
« Reply #27 on: 02 November 2013, 22:21:43 »
So it means they could be torn allready :(
chrisgixer
Re: Desperate
« Reply #28 on: 02 November 2013, 22:23:10 »
Sounds like either;
1 the bolts have come loose
2 the bushes have torn. This wouldn't normally cause knocking on quality bushes though. But cheap ones might.
Where the drop links undone to fit the wishbones, and where they done up again to 60nm?
danzigfan
Re: Desperate
« Reply #29 on: 02 November 2013, 22:29:39 »
The drop links weren't undone
Pages: 1 [2] 3  All   Go Up
