Author Topic: MFL climate panel buttons  (Read 3218 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« on: 03 November 2013, 17:30:22 »
I want to fit a TC button in the blank on my CDX, to provide a switch for manual operation of my intercooler fan. If I have the TC button, do I need anything else behind it, other than the wiring, to allow it to work as a push switchlight? :-\
Re: MFL climate panel buttons
« Reply #1 on: 03 November 2013, 18:00:03 »
I suppose that depends on how the TC switch works? Momentary push or on/off with each push? My guess would be momentary push  :-\  :-\
I'm sure there'll be answers with clever circuit diagrams to latch a relay but an easier idea would be the latching relay at the bottom of the page http://www.vehicle-wiring-products.eu/VWP-onlinestore/relays/relays.php#latch  :y  :y  :y
Shackeng
  • Ramsbury
« Reply #2 on: 03 November 2013, 18:40:24 »
Thanks Andy, I am already going to switch it via a relay, I am just not sure if the switch panel for an Elite with TC will have anything other than the switch and wiring to the relay etc. :-\
« Reply #3 on: 03 November 2013, 18:57:18 »
Sorry ..... no idea  :-\
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #4 on: 03 November 2013, 21:28:16 »
AFAIK, it's a simple N/O switch but when pressed becomes N/C until it loses power and then N/O resumes.
I think I may have one in the garage if you need?
Shackeng
  • Ramsbury
« Reply #5 on: 03 November 2013, 22:17:25 »
I've got one coming thanks. :y
I_want_an_Omega
« Reply #6 on: 04 November 2013, 14:22:09 »
I've had a look at this. The switch only has 3 connections. One will be ground, the other is the illumination input, the other will be a n/o (maybe n/c) connection to ground for connection to the ABS/TC module.
Therefore, anything connected instead of this to use the switch will need to be able to use this momentary change of state.
Another option is to fit a different switch. This can be done quite easily by removing the polarising key from (say) a heated seat switch - that gives you an isolated pair of contacts with LED on the O/P if you wish to switch +12v.
HTH - Rob  :y
Shackeng
  • Ramsbury
« Reply #7 on: 04 November 2013, 17:20:06 »
OK I give up, N/O N/C ??? :-\ :-\ :-\
« Reply #8 on: 04 November 2013, 17:40:52 »
Normally open ie you press the switch to close the contact (switch it ON) & normally closed ie you press the switch to open the contacts (switch if OFF)  :y  :y
Shackeng
  • Ramsbury
« Reply #9 on: 04 November 2013, 17:45:34 »
Thanks Andy, I was thinking it was something nerdy. :y
Shackeng
  • Ramsbury
« Reply #10 on: 04 November 2013, 17:48:53 »
HTH - Rob  :y.
Only problem with this is that the slots for these switches all have different patterns for the pins, like the relay mounts.
« Reply #11 on: 04 November 2013, 17:52:49 »
You're most welcome   :y
« Reply #12 on: 04 November 2013, 17:53:38 »
Nothing that a Stanley Knife can't fix  ;)  ;)
