Author Topic: Poor Intermittent Idle  (Read 1215 times)
viper
« on: 03 November 2013, 18:11:35 »
My 3.0 V6 has a poor intermittent idle when starting. This clears when warm and running.
I changed the Idle Control Valve after checking hoses etc. But problem persists :-\
Then noticed that the idle is poor when there is a wining noise coming from the front passenger side of the car. Underneath the bumper and floor tray.
When this wining stops (sounds like an electric pump) there is a popping and what sounds like the release of air. Like a compressor finishing charging something up.
Following this, the car idles fine.
So what is causing this problem? That when it finishes, the car idles perfectly? :-\
I am lost!
Many thanks
Andy
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Poor Intermittent Idle
« Reply #1 on: 03 November 2013, 18:36:04 »
SAP running or AC Pump?, what happens if you switch AC off?
« Reply #2 on: 03 November 2013, 20:47:58 »
Check rubber hose from SAI not split ;)
viper
« Reply #3 on: 04 November 2013, 21:00:37 »
Thanks guys.
None of the hoses appear to be leaking.
AC is off and it still happens.
There is what sounds like a motor running then clicks and a expulsion of air.
Any thoughts? :-\
Cheers
Andy
