Author Topic: Cor that stinks !!  (Read 1425 times)
2boxerdogs
Cor that stinks !!
« on: 05 November 2013, 18:48:47 »
Hi guys, as the title says, my screenwash stinks noticed a couple of months back, when I used the screenwash it smelt like rotten eggs/sulphur ran it low refilled with fresh water & screenwash smell keeps coming back ..anybody else had this & how did you cure it ?
    • 530D M Sport, 330i Coupe
Re: Cor that stinks !!
« Reply #1 on: 05 November 2013, 19:02:52 »
I drained mine completely by pulling out the pumps and also took the opportunity pull out and clean the rubber gauze fittings and level sensor. Flushed plenty of water through the tank then refitted everything and filled with the proper concentrate of GM Opticlean.  :y
« Reply #2 on: 05 November 2013, 19:06:49 »
Usual cause is cheap screenwash :P
Pull out both pump motors (screen & headlamps) from the reservior and check the filters for growths/blockages, clean & replace. Then top up the reservior with a hot water/bleach mix and leave for an hour or so, then drain the reservior by removing the lowest pump & top up with a good quality screenwash! ;D ;) :y
« Reply #3 on: 05 November 2013, 19:19:31 »
If you don't have the time or inclination to do all the dismantling above .. another fix is to drop baby equipment type sterilising tablets in at double strength ... these will kill off any growth which will hopefully solve the problem. Milton Tablets, or other proprietary stuff will do. We use 2 tablets/gallon to clean the gunge that grows in the caravan toilet flush tank, works a treat .. :)
Do NOT try and use dentist type sterilising stuff, its nowhere near strong enough.
2boxerdogs
« Reply #4 on: 05 November 2013, 23:45:34 »
Thanks, will try the milton cure  first,
