Author Topic: Idling problems - Help!  (Read 3673 times)
Re: Idling problems - Help!
« Reply #15 on: 07 November 2013, 12:34:17 »
I'd avoid 2nd hand items for 2.6/3.2 MAFs, as they tend to misread with age, rather than actually fail.
To reset trims on a 2.6/3.2 with just a cheap OBDII scanner that can only read codes, cause a fault code (eg, unplug MAF with engine running, then plug it back in), then clear the codes with a cheap OBDII scanner. This resets the learned values.
