Author Topic: 3 button key fob  (Read 1846 times)
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
3 button key fob
« on: 06 November 2013, 09:42:37 »
I have 2 key fobs that came with the car, but none of the fobs work. They don't even push down, they're solid??
I can't remember what the score is with getting new fobs and syncing with the car.
I looked for old posts on this, but either blind, stupid or both couldn't see any  ???
Suggestions please?
TIA :y
AKA - Mr Bracket
PAULCDX
Re: 3 button key fob
« Reply #1 on: 06 November 2013, 09:49:07 »
I had something similar a while back mate and ending up sending the fobs off to Martin Imber for repair and upgrade.
When they came back I just put them into the ignition with dash lights on for a few mins and then took them out and they then started working etc....... I think that's what I did anyway? :-[
http://www.imber.me.uk/
Martins Website link Dave  :y
blackviper90210
« Reply #2 on: 06 November 2013, 09:53:59 »
Cheers Paul! :y
AKA - Mr Bracket
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #3 on: 06 November 2013, 09:54:59 »
To sync with vehicle switch ignition on and press lock or unlock button,this only works with fobs that have previously been used with the vehicle :y
other rides
PAULCDX
« Reply #4 on: 06 November 2013, 09:56:03 »
I'm sure Martin will sort your fobs mate and replace for better cases / components   :y
I may be wrong with how I sync'd them back to the car but I'm sure somebody will advise soon  ;)  :y
m.ian
« Reply #5 on: 06 November 2013, 11:08:18 »
Hi, have same problem and have pressed the button on the key with the key in the ignition and ignition lights on, but key will not lock/unlock car.
What next?
« Reply #6 on: 06 November 2013, 11:11:17 »
New battery in fob ?
blackviper90210
« Reply #7 on: 06 November 2013, 11:24:28 »
Its more a case of there is no give under the buttons. They are rock solid.
Hence me trying to work out what would happen if I get new fobs and getting them to work with the car after :-\
AKA - Mr Bracket
m.ian
« Reply #9 on: 06 November 2013, 11:41:08 »
New fobs would mean the use of Tech II to code them to your car, and a Car Pass for the code if you don't already have one  :y
« Reply #10 on: 06 November 2013, 21:44:03 »
egay replacement fob cases are universally shite I'm afraid, the rubber is far too stiff.  I suspect that is what has happened to yours ;)
I recommend a replacement GM fob every time if you don't catch the switches in time before they cause the rubber to fail.
blackviper90210
« Reply #11 on: 07 November 2013, 06:19:12 »
Cheers TB, off to the stealers I will go  ;D ;D :y
AKA - Mr Bracket
