Author Topic: safe mode  (Read 15001 times)
ronomega
  • corby
    • mv6 03
safe mode
« on: 09 November 2013, 14:46:52 »
Hi all, my radio has just gone to safe mode, i did not have flat battery. I put code in and has just gone back to safe mode. When i press the AS button and hold it then knock radio on i do not get any beep. It just seems to be stuck on safe mode, any ideas please.
ronomega
  • corby
    • mv6 03
Re: safe mode
« Reply #1 on: 09 November 2013, 15:36:30 »
i put correct code in three times and its says 07 code
I know its 7 attempts left, but i read on here you have to leave your keys and ignition on for two hours. Is that the correct procedure?
« Last Edit: 09 November 2013, 15:38:37 by ronomega »
Re: safe mode
« Reply #2 on: 09 November 2013, 15:56:12 »
Radio OFF
Ignition ON
Radio on whilst pressing AS button then you should hear the "beep".
Ignition must be left on until display shows "CODE"
ronomega
  • corby
    • mv6 03
Re: safe mode
« Reply #3 on: 09 November 2013, 17:28:47 »
I have done that mate and it will not beep.
Re: safe mode
« Reply #4 on: 09 November 2013, 17:37:34 »
Clearly the code you are entering is incorrect. Absolutely no point whatsoever is attempting that code again ;)
ronomega
  • corby
    • mv6 03
Re: safe mode
« Reply #5 on: 09 November 2013, 17:40:49 »
it will not let me put a code in lad, i used the code before when i changed battery. I cant get it to beep to allow me entering a code,
Re: safe mode
« Reply #6 on: 09 November 2013, 17:50:06 »
So why is counter down to 7  :-\
Anyway, the key point is that ign needs to be on, and radio needs to start off -  turning the ign on whilst holding AS won't work.
If you are in a countdown wait, ign needs to be left on until timer has finished.
ronomega
  • corby
    • mv6 03
Re: safe mode
« Reply #7 on: 09 November 2013, 18:01:06 »
i put correct code in three times, how long will i have to wait to get another attempt? I have original security code on a card when vehicle was bought new
Re: safe mode
« Reply #8 on: 09 November 2013, 18:13:02 »
Are you actually entering the code? Or is it aborting part way through? Its not clear from your posts above.
If you are actually getting to the point of entering the code, and then pressing AS again, then the code you have is WRONG and no point trying again.
  • Auckland
    • Mazda MPV
Re: safe mode
« Reply #9 on: 09 November 2013, 18:17:37 »
Either your radio is faulty or you didn't put the correct code in.
You wouldn't be the first person to type in the ECU security code instead of the radio code (I have more than once ::))
ronomega
  • corby
    • mv6 03
Re: safe mode
« Reply #10 on: 09 November 2013, 18:24:31 »
It will not let me enter a code now, i cant get of safe mode.
Re: safe mode
« Reply #11 on: 09 November 2013, 18:31:04 »
But did it previously?
At 7 attempts remaining, you are in a countdown, and ign must be left on continuously until timer expires. But do NOT enter the same code again, clearly its WRONG!
ronomega
  • corby
    • mv6 03
Re: safe mode
« Reply #12 on: 09 November 2013, 18:42:02 »
Is it the security code on my card or the radio code? i entered security code but i think it is radio code
Re: safe mode
« Reply #13 on: 09 November 2013, 18:43:38 »
Should have two codes on the carpass. When display shows "CODE", enter the one you haven`t tried if unsure of the initial code you inputted
« Last Edit: 09 November 2013, 18:51:00 by RobG »
ronomega
  • corby
    • mv6 03
Re: safe mode
« Reply #14 on: 09 November 2013, 18:51:45 »
i tryed security code only 4 digits
but radio type/code is ****/**** which one is it?
Pages: [1] 2 3 4  All   Go Up
Page created in 0.022 seconds with 20 queries.
