Author Topic: safe mode  (Read 15050 times)
Re: safe mode
« Reply #30 on: 10 November 2013, 12:53:29 »
How long did you leave the ignition on for?
ronomega
  • corby
    • mv6 03
Re: safe mode
« Reply #31 on: 10 November 2013, 12:59:33 »
i left it on for 12minutes last nite.
Surely it cant stay on safe mode all this time.
« Last Edit: 10 November 2013, 13:10:32 by ronomega »
Re: safe mode
« Reply #32 on: 10 November 2013, 13:11:51 »
Multiply that by at least 10
ronomega
  • corby
    • mv6 03
Re: safe mode
« Reply #33 on: 10 November 2013, 13:15:55 »
Are you saying i should leave my ignition on for 2 hours, surely that will kill my battery.
Re: safe mode
« Reply #34 on: 10 November 2013, 13:18:33 »
Ignition & radio on until display shows "CODE" (up to 2 hours), then enter correct code and press "AS" button. Decent battery will sustain that, if unsure whack a charger on it
ronomega
  • corby
    • mv6 03
Re: safe mode
« Reply #35 on: 10 November 2013, 15:26:23 »
I have left ignition on for 2 hours and it is still on safe mode, i assume my radio is broke,
Re: safe mode
« Reply #36 on: 10 November 2013, 16:41:25 »
It can be up to 12hrs, depending how many attempts have been made.
ronomega
  • corby
    • mv6 03
Re: safe mode
« Reply #37 on: 10 November 2013, 17:33:27 »
i made 3 incorrect attempts.
duke101
  • lincoln
    • Omega Estate 2.5 V6
Re: safe mode
« Reply #38 on: 11 November 2013, 06:50:10 »
My guess is that you have a faulty or corrupted eeprom in the head unit preventing it from accepting any codes...i seem to remember my CCR2006 was stuck in safe mode. The eeprom is on a small vertical daughter board which plugs into the mother board of the head unit, replacing it with one from another unit and using that units code would prove the point and get the radio working again if it was indeed an eeprom fault.
Re: safe mode
« Reply #39 on: 11 November 2013, 18:13:26 »
Thats a different error, that says CDC SAFE
ronomega
  • corby
    • mv6 03
Re: safe mode
« Reply #40 on: 11 November 2013, 18:16:36 »
I hate to say it but it is going to Vauxhall, thank you for your help. :y
Re: safe mode
« Reply #41 on: 11 November 2013, 18:29:43 »
If you can get radio to me, willing to look at it. Though, despite being in the same county, you're not exactly close...
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: safe mode
« Reply #42 on: 12 November 2013, 11:52:44 »
7 SAFE means three wrong atempts of a code
You may think you are entering the right code, but I can promise you are not.
Unfortunately 7 SAFE means up to two hours with the ignition and radio switched on, this must be continuous, and yes it is a battery killer if you are not going for a drive - thats the penalty for incorrect code useage
If all else fails after that, send it to me
http://www.dndservices.co.uk/product.php?productid=5921&cat=0&page=1
 8)
Radio & Decoding Technician
ronomega
  • corby
    • mv6 03
Re: safe mode
« Reply #43 on: 14 November 2013, 17:39:18 »
Hi, my code appeared today but i did not leave ignition on, I turned key back to normal and left it on safe mode for 10 mins (no ignition lights on) and hey presto. Cheers all for the help. :y
Re: safe mode
« Reply #44 on: 14 November 2013, 17:45:22 »
To save any further hassle. Now radio is working, if you go through the motions of inputting the code again, once you hear the final "beep" the "code request" will be disabled
Pages: 1 2 [3] 4  All   Go Up
Page created in 0.022 seconds with 20 queries.
