Author Topic: double din radio  (Read 3459 times)
darrenfos
  • eastleigh
    • omega elite manual
double din radio
« on: 10 November 2013, 17:41:01 »
After not much luck with the ccrt2008 i bought, can i buy a aftermarket radio with sat nav and put it straight in without the hassle of wiring its just the ccr2006 is so boring (suppose to be an elite).
omega is like marmite you know the rest
Re: double din radio
« Reply #1 on: 10 November 2013, 17:45:57 »
**ALL** HUs will require some amount of rewiring, except the CDR2005 which is worse than the CCR2006.
Also note, if you have an Elite, you have Bose, and that wipes out any 3rd party upgrade options - you have said often enough yourself that wiring isn't your strong point, so I wouldn't go down this line.
Factory (and Bose compatible) option with Satnav is NCDC2013/5 (5 has the phone, via a seperate telematics unit), but will need wiring changes.
darrenfos
  • eastleigh
« Reply #2 on: 10 November 2013, 17:50:00 »
ok thanks, anyone on hear want to wire a TM loom for me for the ccrt2008 i will compensate any time spent of course
« Reply #3 on: 10 November 2013, 17:52:33 »
Given that you said the CCR2006 is "boring", what do you expect of CCRT2008? Same shite, just with a (900Mhz, is O2/Voda) phone built in?
I'm a bit confiddled what you are trying to achieve?
darrenfos
  • eastleigh
« Reply #4 on: 10 November 2013, 17:56:38 »
 when i had  1999 omega it had the  CCRT2007 which was very good and had the phone there is a ncdc2015 on ebay for £400, also the ccrt700 plugged straight in to my face-lift omega the other day and worked fine,
darrenfos
  • eastleigh
« Reply #5 on: 10 November 2013, 18:14:11 »
will a ncdc 2013 from a vectra fit in a omega ?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #6 on: 10 November 2013, 19:12:27 »
No.
darrenfos
  • eastleigh
« Reply #7 on: 10 November 2013, 19:14:58 »
cheers zirk, i just listed that other unit on ebay cant be bothered with it
Phil
« Reply #8 on: 11 November 2013, 09:10:22 »
No.
Actually YES it will fit in a facelift Omega and will work, HOWEVER the front on the Vectra unit is light grey not dark grey.
Display won't work or fit but head unit will
zirk
  • Epping Forest
« Reply #9 on: 11 November 2013, 11:18:18 »
No.
The Light Grey Panel will be the least of your problems.
it will be configured for the Vectra Canbus system, which the Omega isn't, good chance it wont be Bose, you may get a noise out of it, but no Computer Functions and and Driving around with a Sat Nav with no Display would be fun assuming you always wanted directions to the predefined Home Address on the Red Button.
« Last Edit: 11 November 2013, 11:27:42 by zirk »
Phil
« Reply #10 on: 11 November 2013, 18:00:21 »
No.
Having done it I can confirm the head units are interchangeable.
Half Can Signum to 2000 W plate facelift Omega - CD played and full sound plus the radio and the steering wheel controls worked, but as the newer CID's don't fit in the Omega dash I didn't bother to go any further.
Isn't Bose just a confirguration setting on the head unit anyway? No actual changes in the head unit as its the amp that does the work?
CD prefix head units will not work without lots of messing as these are used in full CAN cars
« Reply #11 on: 11 November 2013, 18:28:45 »
NCDC from a Vectra-C (or any other car) is electrically compatible with the Omega one. The screen isn't.
The pairing is a problem. Don't jump into this unless you know what it entails.
£400 :o :o.  I'm gonna list my spares on egay, if people are stupid enough to pay that sort of money :o
zirk
  • Epping Forest
« Reply #12 on: 12 November 2013, 16:20:51 »
No.
Non Bose 2013/15 drive the speakers directly, is Bose mode the speaker output is changed to suit the input of the Bose Amp, to change the configuration between each mode (via Tech II) you will need the Audio Pass Code from the Donor Car which people seem to forget about when Buying and Selling on eBay.
Having said all that, I still think the Sat Nav feature on them is a nice upgrade over the standard 2006 HU.
