Author Topic: TC and spanner on car lights  (Read 14021 times)
darrenfos
  • eastleigh
    • omega elite manual
Re: TC and spanner on car lights
« Reply #15 on: 11 November 2013, 22:26:48 »
if you can get a code then i could help, also go on ebay, i got my reader £20 free del and works great and clears the codes.
omega is like marmite you know the rest
darrenfos
  • eastleigh
« Reply #16 on: 11 November 2013, 22:33:08 »
i thought you had a face-lift omega which was obd11
m0rmh
  • kendal
    • 2.6 elite
« Reply #17 on: 11 November 2013, 22:37:54 »
its a 2.6 elite on 51 plate
darrenfos
  • eastleigh
« Reply #18 on: 11 November 2013, 22:45:14 »
right good that's same as mine (2001 elite estate manual) im bit confused because your describing the pre omega codes, any way it flashes you count them when it has a slight pause that's the 1st number and so on
darrenfos
  • eastleigh
« Reply #19 on: 11 November 2013, 22:53:45 »
right did you have the self check code first which is 12 x 3 times which is normal then you get the real code after that.
« Reply #20 on: 11 November 2013, 23:04:52 »
Pedal test doesn't cover abs ecu etc I believe, mainly engine codes.  Likely to be duff abs ecu or abs sensor(s).  You need a Tech2 to read the codes ;)
m0rmh
  • kendal
    • 2.6 elite
« Reply #21 on: 12 November 2013, 21:32:06 »
Also got 2106 and 2108 no com with transmission control and no communication ABS/TC,  any idea where to start looking
m0rmh
  • kendal
    • 2.6 elite
« Reply #22 on: 12 November 2013, 21:35:59 »
Did not get that self check, went straight to 2100 code, also mine is auto transmission
darrenfos
  • eastleigh
« Reply #23 on: 12 November 2013, 21:39:59 »
 i will do some fishing around.
darrenfos
  • eastleigh
« Reply #24 on: 12 November 2013, 21:49:37 »
having a look around, you need to contact bba-reman as it look's like your ABS Control Module may have packed up, if so you can send it to them and they repair them,
m0rmh
  • kendal
    • 2.6 elite
« Reply #25 on: 12 November 2013, 21:53:12 »
would have thought abs light would be on rather than tc light
darrenfos
  • eastleigh
« Reply #26 on: 12 November 2013, 21:57:31 »
abs module/speed sensor are linked as they work of the same sensor
m0rmh
  • kendal
    • 2.6 elite
« Reply #27 on: 12 November 2013, 22:00:58 »
:y will look into it
darrenfos
  • eastleigh
« Reply #28 on: 12 November 2013, 22:03:35 »
u said a few things 1, tc light on, 2, code's saying no com, but no specific fault  3,it's pretty common on these cars
« Reply #29 on: 13 November 2013, 02:24:29 »
Said that a few posts ago ::)
Pages: 1 [2] 3 4  All   Go Up
