Author Topic: TC and spanner on car lights  (Read 14023 times)
m0rmh
  • kendal
    • 2.6 elite
Re: TC and spanner on car lights
« Reply #45 on: 15 November 2013, 13:26:32 »
Can I try 1 of the other  switches to test
« Reply #46 on: 15 November 2013, 14:37:14 »
It sounds to me like the gearbox has gone into limp mode. Might be worth taking a look at that. Again, you need to get codes read from the systems really. Do the lights by the gear selector accurately reflect the position of the stick without any flickering or anything?
m0rmh
  • kendal
    • 2.6 elite
« Reply #47 on: 15 November 2013, 18:42:37 »
The lights apear to be ok, no flickering
« Reply #48 on: 15 November 2013, 18:48:40 »
Needs to be another TC switch :y
m0rmh
  • kendal
    • 2.6 elite
« Reply #49 on: 16 November 2013, 11:06:47 »
Got TC switch off, can it be tested with a multi meter, no matter which terminal I touch and press the switch the meter does not give audible sound
« Reply #50 on: 16 November 2013, 12:28:37 »
Yup pins 11 and 12 should give a reading... if not, switch is goosed :y
m0rmh
  • kendal
    • 2.6 elite
« Reply #51 on: 16 November 2013, 13:23:23 »
hopefully the pic has worked, this is the back of the switch,  to me it doesn't look as though it has enough pins, can anyone confirm this, as I guess buttons are interchangeable on the front
« Reply #52 on: 16 November 2013, 13:35:51 »
I quoted the pin numbers from haynes...
One pin is power to the switch.
One is the return to ground.
One is the lamp that illuminates the switch when ignition is on.
Connecting the first two will only give a current when the switch is pressed.
Connecting the first and third will do nothing.
Connecting the second and third will produce a constant current.
Switches not interchangeable.
m0rmh
  • kendal
    • 2.6 elite
« Reply #53 on: 16 November 2013, 13:40:55 »
Ok, just thought that there wasn't enough pins, not had car long so don't know the history
m0rmh
  • kendal
    • 2.6 elite
« Reply #54 on: 16 November 2013, 13:48:08 »
Well the switch is fine, any connections around gearbox I can check,  the pedal test gave- codes 2100  2106  2108, if I could be pointed in the right direction so I'm not checking things that have nothing to do with what I'm looking for. ::)
m0rmh
  • kendal
    • 2.6 elite
« Reply #55 on: 23 November 2013, 19:46:08 »
Got it sorted, easy fix the end, :y
« Reply #56 on: 23 November 2013, 21:04:10 »
Job well jobbed :y
« Reply #57 on: 24 November 2013, 00:02:33 »
Glad you fixed it - its worth sharing the solution with others on here ;)
m0rmh
  • kendal
    • 2.6 elite
« Reply #58 on: 24 November 2013, 09:51:28 »
[/quote]
[/quote]
Had it plugged into diagnostic got the codes 2100 2105 2108 connection errors, checked all wheel sensors, appeared to be ok, checked main ecu connections all ok, lights still on.  Managed to get  connections off abs ecu, looked like a bit of water ingress bit hard to see, used some contact cleaner replaced fitting bingo!!  Must have been enough to make a poor connection,  :y
« Reply #59 on: 26 November 2013, 11:42:58 »
Nice one. :y
It might be worth checking the rubber seal on that connector in case it leaks again. Often, moistening it with a bit of silicone grease before reassembly will help, just avoid getting it on the pins.
Pages: 1 2 3 [4]  All   Go Up
