Pages: 1 [2] 3  All   Go Down
Author Topic: Coolant loss from radiator drain tap??? (NOT HBV)  (Read 9649 times)
grain.ben
Re: Coolant loss from radiator drain tap??? (NOT HBV)
« Reply #15 on: 15 November 2013, 22:03:52 »
Nothing to lose from trying :y
This is true, when I take out the plug, how much coolant will come out? all of it? or some?
« Reply #16 on: 15 November 2013, 22:06:26 »
About 6 litres if my efforts tother day are anything to go by ::)
Proper engine holds about 10 litres, not sure about the desmond :-\
grain.ben
« Reply #17 on: 15 November 2013, 22:08:40 »
Ok, I shall see what I can sort out in the morning/weekend, cheers chaps  :y
Radar
  • Berkshire
    • Elite 2.5 Auto
« Reply #18 on: 15 November 2013, 22:17:33 »
Lol. Best of luck :y
grain.ben
« Reply #19 on: 15 November 2013, 22:20:59 »
Taa muchly  :y
« Reply #20 on: 15 November 2013, 22:27:23 »
Carry a 50/50 mix in a 5L bottle in the car, when I flushed the heater matrix on the 3.2, I got about 4L is back in, you may find it drops as the car is used after a big change  :y
« Reply #21 on: 16 November 2013, 00:02:28 »
When mine did that I tightened the plug a little more with a pair of pliers.That was a year ago and it hasn't leaked since. If you need another plug to put  O-rings on give me a shout.Im sure I have a couple of spare ones somewhere. :y
« Reply #22 on: 16 November 2013, 00:09:41 »
If the expansion cap stays ON, and the expansion tank is correctly filled, then the amount of coolant that will leak out will be restricted by the vacuum in the system, provided you don't allow the system to "glug" a lump of air back in ... ie .. be quick and a finger over the holes as you remove the old tap ... on which there are TWO o-rings ....    :(
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #23 on: 16 November 2013, 09:37:36 »
Worked for too for a while :y.Then my rad split at top and had to replace rad  ::)
grain.ben
« Reply #24 on: 16 November 2013, 10:15:09 »
UPDATE= just been to inspect, it did indeed start leaking over night, but not as much as i thought, the leaking was very minimal, so for now, i poured the small amount of coolant back into a spare container, washed the bucket out, got my pliers and gently nipped up the drain plug (as it was slightly loose) and put the bucket back under there, i will go out in a few hours to see if nipping the tap up has stopped the leak for now.
Cheers Albitz, will keep that in mind, you might just well get a pm over the weekend though depending if its stopped or not  :-\
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #25 on: 16 November 2013, 10:21:55 »
I always drain mine into a kitchen bowl, which goes easily under the car. It seems to hold a gallon, which is all that comes out. Putting  hose on the outlet pipe there is very little coolant loss.
grain.ben
« Reply #26 on: 16 November 2013, 10:30:06 »
Which is what ill be purchasing this weekend for problems i have like this.
I should really go through everything i need really  ;D
« Reply #27 on: 16 November 2013, 12:18:47 »
Pattern rads don't always have the outlet for a hose :y
grain.ben
« Reply #28 on: 17 November 2013, 14:37:26 »
IVE DONE IT  :D :D :D I hope  ;D :-\
got the bits I needed to recycle my coolant this morning, opened the expansion tank, attached my hosepipe to the radiator drain, unscrewed the tap, flowed nicely into my spare 5lt bottle, the rest into a washing up bowl, let it drain, pulled the tap out, went inside to inspect the O rings, and the smaller one at the top had a flat spot on it (suspect), so replaced both O rings, the top one was ever so slightly smaller than the bottom one, went back out, inserted into hole  ::) ;D , it was a lot tighter fit than when it came out, tightened it up. Started filling the recycled coolant back into the tank, 6lts later, started the engine, aircon off, normal blowers on HI and fan full speed, let it run for 10mins while squeezing the top hose to expel any air bubbles, all seemed ok!
Conclusion = im sooo hoping its the O rings and nothing else, so ive put my bucket back under the car and will go inspect later then its fully cold. At the moment, its not leaking  :) , and hopefully it wont anymore.
P.s, this is the first UNAIDED and UNSUPERVISED job ive done on the car without any help apart from the forum  :y :y Ill be so happy that achieved this on my own if the leak stops.  :D
Radar
  • Berkshire
    • Elite 2.5 Auto
« Reply #29 on: 17 November 2013, 16:40:18 »
That's good news :y
Fingers crossed its fixed.  You can think of some other jobs to tackle now!
Pages: 1 [2] 3  All   Go Up
