Author Topic: Anyone ever slipped a disc before?  (Read 3904 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Anyone ever slipped a disc before?
« Reply #15 on: 17 November 2013, 18:03:48 »
thanks boys. steve i'd love to come up and pop some pills with you.... not sure id get out the car tho  ;D
thanks taxi. as said it feels a lot better. the 111 nurse tokd me to take a mix of paracetamol and nurofen and an ice pack. all of this has really helped. but of course it could be the pills making me feel ok. if it dont significantly clear up by tuesday night ill take the day off school and walk to the docs  :y
RIP Paul Lovejoy
Taxi_Driver
« Reply #16 on: 17 November 2013, 18:10:12 »
thanks taxi. as said it feels a lot better. the 111 nurse tokd me to take a mix of paracetamol and nurofen and an ice pack. all of this has really helped. but of course it could be the pills making me feel ok. if it dont significantly clear up by tuesday night ill take the day off school and walkget a taxi to the docs  :y
Fixed that for you  :y
Webby the Bear
  • Northampton
« Reply #17 on: 17 November 2013, 18:15:22 »
to be honest mate i can walk absolutely fine and need to keep moving.  :y
RIP Paul Lovejoy
Taxi_Driver
« Reply #18 on: 17 November 2013, 18:23:45 »
And here i am trying to drum up a bit of trade for Northampton cabbies  ::) ;D
You can walk to the cab and into docs at the other end  ::) ;D
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #19 on: 17 November 2013, 20:30:18 »
I can definitely recommend the support belt, I have one similar to this, http://www.amazon.co.uk/Fitness-Gear-Medium-support-lumbar/dp/B007Q01Z4M/ref=sr_1_6?ie=UTF8&qid=1384720101&sr=8-6&keywords=lumbar+support+belts, and I add sponge padding to act on the required disc area. :y
Allenm
  • Online Online
  • Milton Keynes
« Reply #20 on: 18 November 2013, 10:49:15 »
If it is minor, it will go back on its own - apply cold NOT heat as you want to reduce inflammation.
Best idea is to go to a Chiropractor or if that is not an option a Physio - Physio will massage only, Chiropractor will manipulate when it is safe to do.
If you do any exercise that causes pain - STOP!
HTH
Are you sure? Ive had quite a few slipped disks.....the physio i used to visit used to pop the disk back in, after applying heat to the area and was bloody painful when he did it.
Since then ive used an Osteopath who just massages after applying heat.
Now i use my own method....go see Dr, who will quite happily prescribe 'industrial strength' painkillers (5x the strength, that you can buy over the counter, co-codamol's) and pop the pills until it goes away.
I slipped a disk a week last wednesday and it was pressing on my sciatic nerve, which meant a shooting pain in my left leg and was impossible to press the clutch without much pain and used to limp about when walking. But 4 painkillers a day made it possible to keep working  :)
Today, however i think im on the way to mending, the pain in my leg is less and is nearer the bottom of my leg now (always a good sign  :) ) and i havent taken any painkillers either and have been out in the car without much discomfort  :y
My Docs advise was take the painkillers to move about in less pain, but keep moving about.
The 'old' advice of lying still on your back is now incorrect, as this can lead to DVT's  :y
HTH......but go see your doc and get some painkillers  :)
Yep, I'm sure... my brother is a Chiropractor.  But of course there are some that will do more than the job spec as it were.  My Physio was at great pains to inform me that I could not expect manipulation, that is not how they work.  but I have heard that some do.  Osteopaths are not Doctors, or for that matter regulated, so you are relying on luck that you will get a good and properly trained one.
Taxi_Driver
« Reply #21 on: 18 November 2013, 18:17:48 »
HTH
Ah righto, stand corrected  :y The one i visited must go the extra ( he's actually the one the football club use) . I knew osteopaths arent regulated, but he was recommended to me  :y
But I use my method now, painkillers and wait to see if it gets better on its own......which this time its seems to be  :y
