Author Topic: V6 Plenum  (Read 1975 times)
V6 Plenum
« on: 17 November 2013, 16:33:03 »
Does anyone have a picture of the back of the V6 Plenum  :-\ I found a broken bit off one of the vacuums and need to identify it  :'(
Re: V6 Plenum
« Reply #1 on: 17 November 2013, 17:07:25 »
Look at cems recent pic post in Gen Help ;)
Edit - sorry in Gen Car Chat 8)
Re: V6 Plenum
« Reply #2 on: 17 November 2013, 17:46:04 »
In this picture where its circled in yellow , there is sealant on the end of the pipe where someone has bodged it . It attaches to a plastic pipe to a vacuum . The plastic part of the vacuum has been snapped off  :( So need to know what the vacuum part bit is called so i can replace it .
Re: V6 Plenum
« Reply #3 on: 17 November 2013, 20:22:24 »
Looks like rear multi-ram actuator
Re: V6 Plenum
« Reply #4 on: 17 November 2013, 21:00:07 »
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: V6 Plenum
« Reply #5 on: 17 November 2013, 21:46:14 »
i should have a few of them in the shed.  :)
Re: V6 Plenum
« Reply #6 on: 17 November 2013, 21:55:24 »
Ive had to leave the pipe disconnected , it dont make any difference to the running of the car as far as i can tell  :-\
Is there only one actuator at the back , sure i seen a few vac pipes  ???
symes
  • oxford
    • R reg 940 volvo
Re: V6 Plenum
« Reply #7 on: 17 November 2013, 21:58:22 »
actuator s bolted to rear of plenum---has harness plug into it  :y
Re: V6 Plenum
« Reply #8 on: 17 November 2013, 22:00:58 »
You see where i have circled the yellow . Well that is where the pipe was glued onto the bit thats broken . The bit i need is not in the picture  ;)
Re: V6 Plenum
« Reply #9 on: 17 November 2013, 22:19:38 »
I think its this bit , solenoid is it ?  :-\ :-\
Re: V6 Plenum
« Reply #10 on: 17 November 2013, 22:53:42 »
Ok i think i found it  :)
No 3 in the pic  :y
  • Auckland
    • Mazda MPV
Re: V6 Plenum
« Reply #11 on: 17 November 2013, 23:01:25 »
You are not trying hard enough ;)
Rear multi ram actuator doesn't operate until about 6000 rpm IIRC :-\
Re: V6 Plenum
« Reply #12 on: 18 November 2013, 14:30:38 »
Front at 3000 rpm, rear at 4000 rpm :y
You'll notice once it's plugged back in ;D
Re: V6 Plenum
« Reply #13 on: 18 November 2013, 14:34:38 »
Not hitting 6k with swmbo in the car  :o Car ran ok today barely over 4k  :-[
