Author Topic: Another fan?  (Read 4761 times)
Bob G
  • Gloucester
Another fan?
« on: 17 November 2013, 17:45:26 »
While investigating poor LPG running, (poor coolant flow) I noticed that my main fan was running all the time, put this down to the fact that its side of rad was hot, lpg side was cold.  This usually means giving the heater matrix a flush.  While running to check all I heard what sounds like another fan kick in from under f/r/h arch area.  Have seen something on here I am sure, but a search turned info on ceiling fans, probably my choice of words.  So what did I hear.
Re: Another fan?
« Reply #1 on: 17 November 2013, 18:16:37 »
f/r/h arch area
Sure it wasn`t nearside front arch Bob?
Bob G
  • Gloucester
Re: Another fan?
« Reply #2 on: 17 November 2013, 18:59:51 »
could have been but it was such a shock as not expecting it, 2.0L btw
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
Re: Another fan?
« Reply #3 on: 17 November 2013, 21:30:39 »
I have recently had probs with my LPG with it unusually switching off and on. Discovered that the regulator water supply was hot on the input but only warm on the output.
Initially thought it was the thermostat (as it's fed on the pipe that comes out the top of the therm housing to the reservoir) but as I was getting no thermostat not working symptoms, thought it might be the reservoir as I recently put in a new one.
Turned out the metal insert inside the reservoir connection had become blocked by small rust particles, it has a small bore
Might be worth a look
HTH
Phil
symes
  • oxford
    • R reg 940 volvo
Re: Another fan?
« Reply #4 on: 17 November 2013, 21:39:12 »
or its gas remp sensor on lpg-it fits in gas line before injectors--mine f***** up and made my fans come on and engine temp was higher than normall-soon as I replaced gas temp sensor--all good  :y :y
Bob G
  • Gloucester
Re: Another fan?
« Reply #5 on: 18 November 2013, 17:28:20 »
Symes prob with mine was a temp drop not hotter :), have had this before and found a heater matrix flush seems to cure it, guess it is something to do with a 100% water flow.
Good replies but still no the wiser about the fan noise.
Sir P reservoir take it you mean the coolant reservoir
« Last Edit: 18 November 2013, 17:30:13 by Bob G »
SIR Philbutt
    • PJB Home Services
Re: Another fan?
« Reply #6 on: 18 November 2013, 17:40:59 »
yep  :y
Re: Another fan?
« Reply #7 on: 18 November 2013, 17:59:00 »
How can a gas temp sensor (that only the LPG ecu can read) have any bearing on engine temp and rad fan operation?
Bob G
  • Gloucester
Re: Another fan?
« Reply #8 on: 18 November 2013, 18:05:26 »
Hi James she's poorly on LPG as you can see, about same as when you did heater flush
symes
  • oxford
    • R reg 940 volvo
Re: Another fan?
« Reply #9 on: 18 November 2013, 21:45:50 »
because sensor tell how much gas to inject--goes lean=heat ----as explained by zavoli technician :y :y so lpg can cause issues too
Bob G
  • Gloucester
Re: Another fan?
« Reply #10 on: 19 November 2013, 17:25:01 »
and the other fan noise is???
Re: Another fan?
« Reply #11 on: 19 November 2013, 17:28:05 »
If its going so lean that its causing enough heat for the cooling system to work overtime, I would be seriously worried! :y
Bob G
  • Gloucester
Re: Another fan?
« Reply #12 on: 20 November 2013, 16:24:51 »
James when you free?
symes
  • oxford
    • R reg 940 volvo
Re: Another fan?
« Reply #13 on: 20 November 2013, 21:12:05 »
thats why i took it too some one who knows what they are doing with lpg :y :y-spent all weekend learning my system and got cd/lead to do checks in future-if required :y all i did in return was rebuild his chev v8
Bob G
  • Gloucester
Re: Another fan?
« Reply #14 on: 20 November 2013, 21:45:58 »
tonight it has cut out 4 times on main road running on petrol, eml on but its to dark to cold to late and dressed up to do the paper clip.
really getting pi*** of now  :'(
