Author Topic: breather tubes  (Read 4938 times)
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
breather tubes
« on: 17 November 2013, 19:00:34 »
Can some knowledgeable soul please explain to me where the 4 tubes from the back of the plenum actually go , the ones from the plastic cover, thank you
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: breather tubes
« Reply #1 on: 17 November 2013, 20:01:52 »
The two larger tubes actually join together and, along with the smallest tube, go to the 'breather box'.
I'll have to think about the other one though .....  :-[
Re: breather tubes
« Reply #2 on: 17 November 2013, 20:10:24 »
Looking from front of engine
Pre throttle breather     Post throttle breather   Carbon canister vent (purge valve)   Pre throttle breather
Re: breather tubes
« Reply #3 on: 17 November 2013, 20:21:12 »
Wot 'e sed :y
Toledodude1973
  • IPSWICH U.K.
Re: breather tubes
« Reply #4 on: 18 November 2013, 19:27:15 »
So basically all tubes would need tracing and cleaning out including breather box entry to do a thorough job?
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: breather tubes
« Reply #5 on: 18 November 2013, 19:33:35 »
Yep, absolutely. There's a great guide in the maintenance section  :y
Toledodude1973
  • IPSWICH U.K.
Re: breather tubes
« Reply #6 on: 18 November 2013, 20:00:48 »
Thanks Jonny and its not too difficult?
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: breather tubes
« Reply #7 on: 18 November 2013, 20:06:08 »
Access to the breather box itself is awkward, as is removing the clips!
It's a cinch when you get that far  ;D
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: breather tubes
« Reply #8 on: 18 November 2013, 20:08:52 »
Toledodude1973
  • IPSWICH U.K.
Re: breather tubes
« Reply #9 on: 18 November 2013, 20:27:34 »
Thanks mate having a look at guide now
Toledodude1973
  • IPSWICH U.K.
Re: breather tubes
« Reply #10 on: 18 November 2013, 20:48:52 »
Quoted from guide:
(Remove the 2 breather tubes - 1 small one from the breather box, 1 large one that divides into two from the same breather box.}
Where does the fourth tube from the breather bridge go to? thanks for help
Re: breather tubes
« Reply #11 on: 18 November 2013, 20:54:42 »
Purge valve
Toledodude1973
  • IPSWICH U.K.
Re: breather tubes
« Reply #12 on: 18 November 2013, 20:56:55 »
So just clean that pipe like the others then Rob
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: breather tubes
« Reply #13 on: 18 November 2013, 21:01:53 »
Tbh I'm not sure I've ever totally disconnected that last pipe!
I must have a look into that for next time  :-X  No pun intended  :D
Toledodude1973
  • IPSWICH U.K.
Re: breather tubes
« Reply #14 on: 18 November 2013, 21:03:43 »
You've all been a great help as usual thanks
