Author Topic: Headlight Washer Jets  (Read 4020 times)
amba
  • Medway towns
    • German V6
« on: 18 November 2013, 16:04:17 »
Not working with headlights on. >:(
Checked water  ;D.full. :y.checked fuse#26 and all fine as number plate light is also functioning correctly. :y
Windscreen washer working. :y..is the pump the same for both ?
Is there a relay for the headlight washers ? and where please ??
Re: Headlight Washer Jets
« Reply #1 on: 18 November 2013, 16:09:22 »
Separate pumps I think. Worth sticking it in a bottle of water, see if its working?
« Reply #2 on: 18 November 2013, 16:18:43 »
As Mark says, separate pump
Relay & fuse at front of relay box by battery
amba
  • Medway towns
    • German V6
« Reply #3 on: 18 November 2013, 16:35:10 »
Pump knackered..just removed and put 12volts across and not a squeek so quick search now.
Hope Mr.MOT man is kidn to me in the morning as long awaited test and would hate to be failed on a simple washer pump..fingers crossed he is kind to me  :(
« Reply #4 on: 18 November 2013, 17:11:52 »
Expect a fail. If fitted they have to be working.  ;)
amba
  • Medway towns
    • German V6
« Reply #5 on: 18 November 2013, 17:37:21 »
Well pump is removed and despite my best efforts to revive it ..it is dead  >:(
3 months getting this far to be thwarted by a simple electric pump...oh well test is booked tomorrow at my usual place so just have to hope they accept I will get it replaced asap and be kind and issue ticket as dont now have time to fix it or replace
Interestingly the MFL on the driveway with headlight washers has a different pump and the electric plug is also different so cant even swop them over
amba
  • Medway towns
    • German V6
« Reply #7 on: 18 November 2013, 18:21:25 »
Top work RobG  :y
Fingers crossed for tomorrow then but atleast spare is on its way so if doesn,t pass can rebook for Friday morning  ::)
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #8 on: 18 November 2013, 19:05:53 »
Is it easy to remove the jets? If they're not fitted, they can't be a fail. I think!
amba
  • Medway towns
    • German V6
« Reply #9 on: 18 November 2013, 19:53:42 »
That went through my mind,John,however I also thought if HID,s were standard ,self levelling and washwrs was compulsory.
If I remove the jets ,even given test is at 9.15am,and really dont want to be pulling bits off first thing in the morning,I am just going to bite the bullet and put my hands in fate.
Should it fail I have another ,thanks to RobG ,s link,on its way, so will just rebook for Thursday afternoon for a retest as only 15 mins to replace...sods law it might have other issues
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #10 on: 18 November 2013, 19:59:05 »
There's always something  ;D
Good luck pal  :y
« Reply #11 on: 19 November 2013, 17:12:29 »
Well :-\ :-\
amba
  • Medway towns
    • German V6
« Reply #12 on: 19 November 2013, 17:20:18 »
See my post in "general chat"
The man from the ministry. ;D ;D ;D."He said YES !! " :y
« Reply #13 on: 19 November 2013, 17:23:22 »
:y :y
amba
  • Medway towns
    • German V6
« Reply #14 on: 21 November 2013, 16:19:37 »
Replacement pump arrived this lunchtime in the post.
Simple 10 mins job to replace and all is good and headlights now get a hefty wash.Just need to do a bit of adjustment on the aim of the jets as seems to be like a water cannon going off...they certainly are "high pressure" compared to the older MFL style type.
Thanks for your help guys :y
