Pages: 1 2 [3]  All   Go Down
Author Topic: Failure of low energy light-bulb .........  (Read 4653 times)
Re: Failure of low energy light-bulb .........
« Reply #30 on: 19 November 2013, 14:59:26 »
I bought a crap load from Tesco's about 15 years ago when they where doing a special green deal on them, think they worked out at about 30p each, all still going strong except the ones I fitted to lights that had dimmers on them, although they lasted a fair while before giving up the ghost.  :y
You did better than me then, I bought a CFL which was specificaly designed for use with dimmers (Megaman), I had it on apprax half brightness and after an hour I heard a buzzing noise and bang, it blew. Took it back and had it replaced and the same happened again!
« Reply #31 on: 19 November 2013, 15:15:23 »
If Megaman stuff is failing that quickly it doesn't bode well for the cheap brands. ::) I replaced some GU10 halogen lights in the kitchen with Megaman low energy jobs and I think one failed pretty early on. The rest have lasted for probably 5 or 6 years, although I've noticed they now take an age to reach full brightness. I have some B&Q "own brands" alongside them, so we'll see how they compare.
There seems to be a bit of a bathtub curve with these. You get quite a lot of early failures, and those which survive seem to do well if they are a known brand.
I've got an outside light on a dawn-to-dusk switch with a 9W low energy bulb in, again a Megaman, I believe. I've only just had to change the bulb, and I reckon it'd been in there 8 years or so. It's on all night, so probably averages around 10-12 hours a day. That's a lot of hours.
When used within the house, though, I reckon they don't last any better than normal light bulbs.
I guess the answer is to leave them on (which makes them less energy saving, but probably not a bad idea given how long some of them take to reach a decent brightness).
The other thing that might be a factor is that the electronics is built down to a price, and gets really hot, especially in a light fitting. Most seem to fail at startup, although I've had a few that get slow to start and then start flickering. I wouldn't mind betting that on most the electronics gives up the ghost before the tube has reached the end of its' life.
Hopefully, these daft things will turn out to be a temporary measure before LED lighting gets more usable, but the latter has got some way to go before I'll be using it as I find the quality of light from LED devices about on a par with candles at the moment.  ;)
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #32 on: 19 November 2013, 16:08:25 »
I was in a Spanish supermarket the other day looking for a bulb. A chap was stocktaking and knocked about thirty bulbs off the rack onto the floor. That may well be thirty premature failures for some suckers. :o
Taxi_Driver
« Reply #33 on: 19 November 2013, 18:09:42 »
I'm thinking about getting 4 of these....
 http://www.ledhut.co.uk/spot-lights/mr16-led-bulbs/mr16-smd-led-20-pice-best-internet-price.html
to replace the 4 x 50w 12v halogen's in my kitchen..... :-\
AndyRoid
  • Hants
« Reply #34 on: 19 November 2013, 18:27:25 »
I think (actually, I believe) you have hit the nail on the head Kevin, cheap components = shite lifespan......end of IMHO.
Taxi_Driver
« Reply #35 on: 19 November 2013, 18:43:16 »
I totally agree  :y I dont mind buying 'store' branded kit....but dont it expect it to last long.....unless i know who made it...
For example, my notebook is Advent....Intel motherboard and Intel processor .... cheapish to buy at the time but as its mostly Intel  :y
« Reply #36 on: 19 November 2013, 21:02:50 »
Yep, like my gas boiler with 85C rated cheap chinese electrolytics mounted on a PCB a few inches below the burner housing. ::) Needless to say, it has 105C Panasonics in now, and actually works properly. ::)
So, for want of a few pence saved on the electronics (which ought to last practically forever) we are throwing away the nasty, polluting part of the device unnecessarily. >:(
Pages: 1 2 [3]  All   Go Up
