Pages: 1 2 [3]  All   Go Down
Author Topic: New pikey wagon !!  (Read 9555 times)
2boxerdogs
Re: New pikey wagon !!
« Reply #30 on: 24 November 2013, 19:49:25 »
The terracan (2.9 diesel) returns 27mpg when towing our Elddis twin axle, solo I  have had 38mpg on a long run..
« Reply #31 on: 24 November 2013, 20:46:23 »
What specs is the Terracan then .... permanent 4x4? weight? bhp? My R320 does 30-ish on a run  ???
2boxerdogs
« Reply #32 on: 24 November 2013, 21:41:25 »
Hi, the Terracan is not permanent 4 wheel drive has selectable 4HI & 4LO , 4 cylinder DOHC/2902CC..Max power KW/BHP 120/160@ 3800 RPM.. Torque Nm/lbs ft 345/254 @ 1750rpm..Gross vehicle weight kg (lbs) 2,620 (5776)..Max towing weight kg (lbs) Braked kg (lbs)2,800 (6,173) Unbraked 700 (1,543 )
« Reply #33 on: 24 November 2013, 22:12:18 »
Though yours has less power & torque than mine, it's heavier but NOT permanent 4 wheel drive which I think is where mine looses much of it's fuel consumption (mine is around 2300kg 224bhp & 375lbft)
2boxerdogs
« Reply #34 on: 24 November 2013, 22:25:03 »
Yes permanent 4x4 does  make a difference, had a 2 litre Subaru forester before (petrol) only managed 32 mpg at best..
Pages: 1 2 [3]  All   Go Up
