Where to draw the line between "mates rates" and "wanting something for nothing"
Started by maracus, 22 November 2013, 15:21:22
Webby the Bear
So doing your mates' work has prompted you to spend on tools you don't need  ::)
Before shelling out ANYTHING remove the stat and test it in a pan of water and bring to the boil and observe it's opening temperature. That way you haven't bought parts that MAY fix the problem and you've left the most costly test til last. If it was an Omega the bonus is that if it is the HG the stat has to come out anyway so you're half way there....not sure about the bimmer in question  :y
I remember when I had a performance issue......with my Omega, not anything else  ::) my first instinct was to chuck second hand parts at it and after valuable advice on here I no longer do that. Testing, testing, testing.... :y
RIP Paul Lovejoy
maracus
You're quite right I make too many assumptions! Ill test it tomorrow  :y it looks a piece of cake to get to so shouldn't be a big problem to whip it off to test.
The weather is here... Wish you were beautiful!
maracus
Well I had a look at his thermostat and sure enough its seized solid! Had it boiling in a pan and there was no sign of movement so I've told him to get a thermostat and hopefully the heads ok as there seems to be no other symptons of h/g failure. Fingers crossed it is just that lol
Webby the Bear
Quote from: maracus on 25 November 2013, 10:10:11
Good work mate  :y
RIP Paul Lovejoy
maracus
Quote from: Webby the Bear on 25 November 2013, 12:36:02
Good work mate  :y
Cheers  :y only trouble is, now he's on about getting a second hand thermostat from a scrap yard.  :o I did tell him not to mess about with a secondhand one as it might be just as bad. Hey ho.
Quote from: maracus on 25 November 2013, 13:19:59.....
You just can't help some people  ;D ;D
Webby the Bear
hahahaha ;)
i suppose though if you test the second hand one and its ok..... and its not too much of a pita to do ???  :-\
RIP Paul Lovejoy
maracus
You can take a horse to water...
The best part is, I told him last week when I first looked at it, I'm not convinced your gaskets gone. Don't get a gasket set yet mate. So he got one anyway. Now the shop he got it from won't issue a refund, I'm assuming because its a special order  ::)
Webby the Bear
RIP Paul Lovejoy
maracus
Good work mate  :y
henryd
Quote from: maracus on 25 November 2013, 13:45:02
Have you checked that the water pump is actually pumping water,seen quite a few where the plastic impeller has broken up or come off causing similar issues,it can bugger the stat as well due to localized overheating.
other rides
maracus
Quote from: henryd on 25 November 2013, 18:37:37
Maybe, that would explain why the thermostat seized in the first place, but its since had a recent water pump fitted anyway (I think as a result of it overheating). Im pretty sure it is pumping ok, but you've just prompted me to check that the belt tensions good and that its turning sufficiently when it goes back together  :y
The latest I've heard is that the fella has managed to track down a replacement thermostat of the new variety from autoparts or someone, for a bargain £35 (a bit better than the other quotes of >£70! So he's going to get one of those  :y
