Author Topic: Still not running right  (Read 2885 times)
Re: Still not running right
« Reply #15 on: 23 November 2013, 19:49:46 »
Needs one of those new Redberry Pi thingy's in there.  :-X
RPi doesn't have the legs to run the site, due to lack of memory and cpu grunt.
(thats a slight lie, it can run it with a fast Class 10 card, but is too slow to be useful once traffic ramps up)
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #16 on: 23 November 2013, 22:14:26 »
Trouble is on a busy server once processes start stacking up, taking even more resources, it is on a path to nowhere.  :o :o :o :o
chrisgixer
« Reply #17 on: 23 November 2013, 23:42:33 »
Seems to have settled down :y
...hopefully I haven't just jinxed it. :(
« Reply #18 on: 24 November 2013, 12:51:33 »
Indeed, Rods2, once a Linux server dives into swap due to a disk i/o loading, the system will die fairly quickly, and Linux has a god awful desire to swap before releasing buffers.
Trouble is, I'm not sure what is causing the i/o latency to spike for reasonably extended periods. Disk throughput seems to be about normal just as it starts (but drops off, obviously, during the problem period).
Across the hypervisor, our baseline latency on the HP Smart Array is single digit, but will spike to over 100ms for 15mins or more, which certainly kills all Linux VMs, as they swap rather than release disk buffers, compounding it (though the OOF main server swaps to SSD, so has less impact to hypervisor). The Windows and Solaris VMs cope better.
I think the problem lays at the hypervisor level, as I've halved the amount of ram that the OOF server is allocated, and it seems to be far more stable, with only one brief alert (a slow response) overnight. But nothing has changed at that level. Hardware has been up since the fire, no updates to firmware or hypervisor have taken place....
« Reply #19 on: 24 November 2013, 12:56:26 »
If you need help with it just let me know.  :y ;D ;D
« Reply #20 on: 24 November 2013, 12:57:38 »
Got any steel toecapped boots? Mine melted.
« Reply #21 on: 24 November 2013, 13:04:33 »
Funnily enough, yes I have a pair.  :y Can also access a 14lb hammer.  :)
« Reply #22 on: 24 November 2013, 13:05:25 »
I was thinking more a branch, Faulty style....
« Reply #23 on: 24 November 2013, 14:14:54 »
I'm sure I can recommend someone to puke all over it, they will leave no crevice unsoiled :-X
chrisgixer
« Reply #24 on: 24 November 2013, 14:21:20 »
O-oh. Imagine that in the back of a vxr8 taxi :o
relluf
« Reply #25 on: 24 November 2013, 14:37:54 »
Have you tried switching it off and......................
Ill get me coat!
Really well done TB. All your effort is appreciated :)
« Reply #26 on: 24 November 2013, 15:07:44 »
Rest assured, the type of work that car will be doing is worlds apart from some of the shit I put mine through :y
