Author Topic: Wanted For F/L  (Read 2859 times)
amba
  • Medway towns
    • German V6
Wanted For F/L
« on: 25 November 2013, 12:16:14 »
Had hoped recent replacement would work but not so as it leaks badly and pipe union is busted. :'(...therefore I need the following if anybody can help. :y
Headlight washer pump with the short section of pipe fitted that connects to non return valve ,also the rubber bung that seals the bottom of the pump into the reservoir ,along with both pipe spring clips.  :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Wanted For F/L
« Reply #1 on: 25 November 2013, 13:14:33 »
Fairly sure the Screen and Headlight Pumps are the same, as I cant remember which one I nicked from the plod Im breaking, should have most of the piping your talking about as well if it helps.
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
Re: Wanted For F/L
« Reply #2 on: 25 November 2013, 13:34:15 »
If Siri has not got what you want I'm 99.9% I have  :y
joff
  • swindon, wilts
  • Discovery TD5 ES
Re: Wanted For F/L
« Reply #3 on: 25 November 2013, 13:36:27 »
That's Zirk, I-Pad don't you just love it
Re: Wanted For F/L
« Reply #4 on: 25 November 2013, 13:42:47 »
Nope
zirk
  • Epping Forest
Re: Wanted For F/L
« Reply #5 on: 25 November 2013, 13:54:55 »
Thanks fojj
zirk
  • Epping Forest
Re: Wanted For F/L
« Reply #6 on: 25 November 2013, 13:58:38 »
Nope
Ok, thanks Rob, thought they were the same, will have to check what I nicked then, fairly sure it was the lower one, if memory serves me, lower one is screen, higher one is headlights.
amba
  • Medway towns
    • German V6
Re: Wanted For F/L
« Reply #7 on: 25 November 2013, 14:12:15 »
Hi Guys.
Yes it is the pump at the top of the reservoir.It has the shorter section of thick pipework going to the 1 way valve .
I need the pump with the short bit of pipe attached( as the push on sleeve with a forward/back connection is missing on mine) and also the small spring clip that secures the pipe end to the 1 way valve....also the black rubber gromitt seal for the reservoir to the base of the pump.
Hope all the above makes sense. :y
PM with price/payment details please :y
zirk
  • Epping Forest
Re: Wanted For F/L
« Reply #8 on: 25 November 2013, 14:51:42 »
PM sent.
Chris.
amba
  • Medway towns
    • German V6
Re: Wanted For F/L
« Reply #9 on: 25 November 2013, 17:24:41 »
And replied with details back in the morning :y
