Author Topic: LPG Doughnut Tank  (Read 5095 times)
LPG Doughnut Tank
« on: 31 May 2008, 21:10:58 »
Are we 100% sure that when these are fitted in a saloon spare wheel well on the passenger side, it does block access to the light cluster?
Marie
    • 2ltr LPG Estate
Re: LPG Doughnut Tank
« Reply #1 on: 31 May 2008, 21:14:16 »
yes i would have thought so tunnie. but this is dependent on the size of tank you put in too. my tank is the same size as my spare ( i have a full size spare)
try gettin to the cluster when the spare is in its place. to see how much room you have.
sassanach
  • trowbridge
« Reply #2 on: 31 May 2008, 21:15:32 »
sort off,you CAN work around it
« Reply #3 on: 31 May 2008, 21:16:43 »
Reason i ask is i have had my saloon for 3 years now, and i have never touched the light clusters at the back, no bulbs have gone in 3 years!
Only bulb to go so far is a drivers main one.
HolyCount
« Reply #4 on: 31 May 2008, 21:18:50 »
Any feasability in changing them for LED light bulbs before setting the tank in place ? ---- that should minimise the chances of a failure and the need to get back in there.
« Reply #5 on: 31 May 2008, 21:19:48 »
LPG was 69p a litre at the local BP today, petrol was £1,19.
Even with my super low millage i could get it back in a year.
I spend about £130 a month on fuel (2 tanks)
So that works out at £1,560 a year in fuel.
£700 for the DIY kit?
Less than 12 months use and its paid for itself
Marie
    • 2ltr LPG Estate
« Reply #6 on: 31 May 2008, 21:19:53 »
well if your going to fitt a tank why not as a precautionary measure replace all the bulbs in that cluster its not as if they cost the earth and keep the ones you take out as spares.
just an idea but thats what i would do!
edit: i have lost my touch Need to type faster!
« Last Edit: 31 May 2008, 21:20:35 by marie »
« Reply #7 on: 31 May 2008, 21:22:30 »
Was thinking that, I have not replaced any in 3 years! so if they all do me another 3 years would be fine.
sassanach
  • trowbridge
« Reply #8 on: 31 May 2008, 21:24:38 »
with the tank in place its easier to remove the light cluster complete,however you only have to loosen the strap holding the tank down and tilt it to one side to gain access.
« Reply #9 on: 31 May 2008, 21:26:33 »
Cheers for that.
Its all markey marks fault, he got me thinking i would only do it to an estate... but that got me thinking about doughnut tanks again.
As i don't want to loose boot space or give up my sub!  :D
Marie
    • 2ltr LPG Estate
« Reply #10 on: 31 May 2008, 21:33:04 »
Cheers for that.
the doughnut tanks that stand on there side from what i have heard can be quite a pain in the arse to set up. thats what jeremy told me when i brought my kit. but hey that could just be his opinion :-/
HolyCount
« Reply #11 on: 31 May 2008, 21:33:33 »
You just KNOW if one bulb goes, the others will follow shortly !
« Reply #12 on: 31 May 2008, 21:34:40 »
Cheers for that.
Setup in terms of mouting? or cause all the gas stays at the bottom? lol
« Last Edit: 31 May 2008, 21:34:51 by tunnie »
Marie
    • 2ltr LPG Estate
« Reply #13 on: 31 May 2008, 21:36:22 »
set up i think he said cos yu have to get them to sit perfect or you get snags
« Reply #14 on: 31 May 2008, 21:41:41 »
Pages: [1] 2 3 4  All   Go Up
