Author Topic: bonnet catch  (Read 7430 times)
Bob G
  • Gloucester
bonnet catch
« on: 25 November 2013, 14:23:21 »
Strange one, tried to open bonnet but catch will not release, the cable is not broke plenty of spring tension on it.  On pulling can hear like a catch being pulled then slipping, I think I may have left something on the wing so it is forcing bonnet up that tad to much, should be able to clear I hope by having someone bounce as I pull.
If however that does not work any other tricks other than ruining a good grill.
2.0L with A/C
Re: bonnet catch
« Reply #1 on: 25 November 2013, 14:29:43 »
Get a mate, while one pulls the bonnet release, the other pushes down/pulls up the bonnet  :y
Re: bonnet catch
« Reply #2 on: 25 November 2013, 14:40:10 »
Get someone to push down hard while you pull the release .. do NOT "bounce" it... just a firm downward pressure on the forward edge... usually works first time that way
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: bonnet catch
« Reply #3 on: 25 November 2013, 15:16:12 »
If you dont have any mates, (probably wont have if you keep double posting  ;) ) use some cable or string around the latch to the steering wheel then lock the wheel to tighten, then wriggle as said, once open adjust the tension of the latch with the adjuster.  :y
Bob G
  • Gloucester
Re: bonnet catch
« Reply #4 on: 25 November 2013, 17:23:27 »
No idea why it double posted, probably rushing  ;D will let you know how it goes
zirk
  • Epping Forest
Re: bonnet catch
« Reply #5 on: 25 November 2013, 17:43:16 »
Well its been merged now mate, so thats shut me up then.  ;D
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: bonnet catch
« Reply #6 on: 25 November 2013, 17:45:37 »
Bitch  ;D ;D ;D
Keith ABS
  • Maldon Essex
Re: bonnet catch
« Reply #7 on: 25 November 2013, 19:23:52 »
  As you pull the release lever, try a thump on the rear right hand corner. Sometimes sorts it
Keith B
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: bonnet catch
« Reply #8 on: 25 November 2013, 19:38:49 »
Having a good wife sit on the middle of the bonnet, over the catch, while I pull the lever, never fails. Then I find a spanner or some other tool under the bonnet, which had been jamming it. I have done it a dozen times.
Re: bonnet catch
« Reply #9 on: 25 November 2013, 22:53:00 »
Having a good wife sit on the middle of the bonnet, over the catch,  ......
I'd need a new bonnet!  ::) ::) ::)
Bob G
  • Gloucester
Re: bonnet catch
« Reply #10 on: 27 November 2013, 00:06:14 »
Bonnet free I had left the washer tank cap/dip stick on the slam panel :(
jerry
Re: bonnet catch
« Reply #11 on: 29 November 2013, 11:55:16 »
And boy, am I fed up of having to persuade the better half to come outside to help do this everytime I need to top up washer fluid/check oil/jumpstart etc etc... ;D
zirk
  • Epping Forest
Re: bonnet catch
« Reply #12 on: 29 November 2013, 12:20:07 »
Adjust the strap then, I reckon with a scredriver in your hand and bonnet up, 9 seconds, start to finnish, job done  :y
symes
  • oxford
    • R reg 940 volvo
Re: bonnet catch
« Reply #13 on: 29 November 2013, 15:02:55 »
open bonnet look at front plastic cover on top of rad--on right hand side there is an 8mm bolt head-this holds bonnet release cable-loosen ir and pull outer cable to the right-3/4mm will be enough -----that is how you do cable adjustement :y :y
jerry
Re: bonnet catch
« Reply #14 on: 29 November 2013, 15:09:06 »
cheers, will try this later :y
