Author Topic: taking out air con  (Read 1566 times)
ConorD
  • Ireland,Co.Limerick
    • Opel
taking out air con
« on: 25 November 2013, 23:09:33 »
hi i was just wondering is their any easy way on taking out the air con out of the omega and removing the condenser on the front of the car so more air will be getting at the radiator to cool the car. Thanks :y
Re: taking out air con
« Reply #1 on: 25 November 2013, 23:29:09 »
2Woody is your man if you really want to. The original set up is more than capable of supplying enough air over/through the main rad  ;)
ConorD
    • Opel
« Reply #2 on: 25 November 2013, 23:50:30 »
Thanks pm'd him their askin him :y
« Reply #3 on: 26 November 2013, 18:29:51 »
Do you have a cooling problem? Remember it's designed to have the aircon there, I've taken the 3.2 in 35 degree heat through London, temp has never been an issue.
If its running hot you have other issues, such as stat problem or a blockage  :y
« Reply #4 on: 26 November 2013, 19:33:05 »
Dumped the air con/condenser on 2 now , only as the condenser's were rotted through . Apparently air con does zap a bit of power but not that you would know on a V6  :) , Oh also dumped the twin cooling rads on the front of the condenser . Now in the shed .
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #5 on: 26 November 2013, 19:57:41 »
Isnt this a simple case of evacuating the refrigerant (if any in system) and then removing the condenser?
As Tunnie mentioned... if you're having over heating problems look to the cause of that first... blocked rad, air in cooling system, stat etc etc
This is a pure guess but if you gave the car ''better cooling'' you're in danger of it over cooling and never getting up to temp. I would guess.  :-\
RIP Paul Lovejoy
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« Reply #6 on: 27 November 2013, 07:51:56 »
Depends if the thermostat is working or not 8)
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
