Head gaskets or change engine.
Started by MadMark73, 26 November 2013, 20:00:10
Quote from: Andy B on 26 November 2013, 21:09:11
Quote from: MadMark73 on 26 November 2013, 21:01:34
Cant paperclip as no eml bulb, but no codes if I plug in a reader.
As RobG says, 3.0 are NOT OBDII compliant  ;) ;)
Neither is the 2.5, what the OP is referring to ::) ::)
jtypecav
I'm in Bath and have a variety of cheapo readers as I had to get my 2.5 Cavalier / Omega mish-mash talking reliably from a field in somerset!
As others have said, I'd be very surprised if it wasn't lit up like an xmas tree with at least something!
Quote from: jtypecav on 26 November 2013, 21:14:03
Indeed, there will be loads of codes  :y
It needs a bulb put back in the dash and paper-clip test done.  :)
Quote from: RobG on 26 November 2013, 21:13:53
:P :P :P :P :P :P  ::)
martin42
Ask yourself why the bulb was removed from dashboard,because it has problems the seller was hiding from you  :y
MadMark73
Quote from: The Mad mechanic on 26 November 2013, 21:23:57
Beginning to look that way.
MadMark73
I am now being told by SWMBO (her car), that she dreads having to put fuel in as it doesnt always want to start if the engine is hot.
To be honest we are going to go around and around in circles, until you get the codes read.
Hot starting could be crank sensor, or number of issues. But you are pishing in the wind without codes  ::)
Quote from: MadMark73 on 26 November 2013, 21:31:56
Sounds like crank sensor issues as well. As said, whack a bulb in and clip for codes
MadMark73
Will take dash out over the weekend and post codes after.
As others have said - poor hot starting likely to be failing crank sensor.
Misfire likely to be due to the oil in the plug wells, caused by failed cam cover gaskets probably due to bunged up breather system.
Water loss probably failed HBV - feel for wetness drivers side down behind plenum.
Failed head gasket on a 2.5 V6 is extremely rare - the other causes listed above are common ;)
chrisgixer
Don't trust that garages diagnosis. If we all had a pound for every miss diagnosed head gasket we see on here TB would of had a new server years ago.
As said, add up all the usual common faults on this engine and its easy to end up right where we are now.
Pressure test the system to find the coolant leak, if its not the hbv which is fairly easy test with ac on or off.
MadMark73
Quote from: dbug on 26 November 2013, 22:16:00
What and where?
MadMark73
Quote from: chrisgixer on 26 November 2013, 23:15:26
How do I pressure test the system?
