LPG Donut Tank - 76L - Saloon
Started by tunnie, 30 November 2013, 14:22:48
Broomies Mate
Would 50KG's be a good idea tucked right into that corner?
Admittedly it's not a huge weight, but........  :-\
Fair point, but what does the spare weigh, probably 15kg or so :-\
chrisgixer
Quote from: Broomies Mate on 30 November 2013, 20:39:34
Makes no odds. Given the drives counters it. Even leads the driver, there's no measurable difference in ride height Accross all four corners. There's also a tolerance of 10mm +/- 5mm. :)
chrisgixer
#33
Quote from: D on 30 November 2013, 20:32:14
Quote from: chrisgixer on 30 November 2013, 18:53:08
4 holes are much easier to install, flow more gas, switch over reliably, don't switch back for no reason, and the float valve doesn't rattle against the side of the tank in corners. I especially like the inference that it depends, somehow, who fits it. Yeah, ok ;D
I guess the 4 hole was invented for er, what reason? Oh I know, better safety, better reliability, and economics. All 4 components in one valve means a failure of one means replacement of all. A far more sturdy construction on the outside of the tank rather than the side of a pokey little hole in the middle that impossible to see into and around corners.
....Ahem, cough cough <sarcasm mode off>  Apologies, must be having a bad day. ::)
With a suitably designed multi valve, properly installed, I have had none of the issues you claim to plague single hole tanks. If I were installing a kit into a Vxr,then perhaps you need high end components. But for a run of the mill Omega it seems like overkill. Perhaps the stag kits are poorly designed? After all it is a budget kit. Personally I would put money into better quality injectors than a 4 hole tank, which by the way is significantly more expensive. Well at least the ones I looked at were.
Edited to add: This is on a standard cylinder. The toroidal tanks are too small to have any useful range on an Omega.
Stag don't design multi valves....ecu's and presumably looms yes. It's the software that's stag, nout to do with the components. I have no idea if the stag system is well designed or not, but there's several members here happy with it.
...but note, none of those members, you included D, has the any experience with owning a multivalve in an UPRIGHT TOROIDAL.
Its good to see you've finally noticed the difference between your set up and the topic of this discussion. As said earlier, last I looked, no 4 hole exists in an upright toroidal. Now if a four hole does now exist, that would be different. Go for the upright toroidal and MAKE the damn thing fit as that's worth perusing.
To be totally fair, I didn't see why a single hole upright toroidal would be problematic either, BEFORE owning one. It's ok for plodding about, but upgrade your elites suspension and a new envelope of performance opens up that simply isn't possible on the standard suspension so affecting the valve in corners. Although Tunnie may not be concerned by that to tbh  its still not something that could be described as satisfactory.
I would add, I would never attempt to pas comment on cylinder single hole, having never owned one. Because rightly, I would not be able to "see why it wouldn't work" either D! At least compare like with like. ;)
We are aware of the poor range, as implied in the first few posts, and the suggestion of a larger capacity tank than the 55l tanks that are known to fit. 4 litres short of the 80l cylinders most of us have AND a full size boot space is worth having.  ::) do try to keep up at the back ;)
D, I think your multivalve is a high flowing one. I know I had a long discussion with Tubbs over the issues experienced with the standard one Chris had fitted ;)
chrisgixer
Quote from: Lazydocker on 05 December 2013, 00:55:06
Matters not. Assuming those upright Multi valves are available in the uk now. Wish I'd known that before.
I'm tempted to change mine. But then, how often do I need the full boot space these days. :-\
Quote from: chrisgixer on 05 December 2013, 01:03:35
Don't think they are, although one could probably be modified. Could you really cope with the crappy range?
chrisgixer
Quote from: Lazydocker on 05 December 2013, 01:08:16
Well, as said earlier, only if a size similar the 80l would fit. Or be made to fit. I'd be prepared to modify the wheel well/boot floor a bit to get 76l in, or whatever.
chrisgixer
There posts missing on this thread. I posted some links to upright 4 hole donuts that aren't present.
Hold on.
chrisgixer
Click the tabs for sizes and specs
Upright (stand) toroidal 4 hole. Various sizes up to and over 85l, unless I've miss read, again?
http://www.elpigaz.com/en/stand-moremo/
About 2/3rds the way down this page...
http://shopgas.pl/Zbiorniki-LPG-i-mocowania(2,21668,).aspx
But my Czech is non existant at best :-[
Guess if you add it to the basket it would produce a price :-\
Quote from: ex taxi al on 05 December 2013, 02:19:00
Polish.  :P  Use Chrome and it will translate it for you.  ;)
chrisgixer
Quote from: Sir Tigger on 05 December 2013, 22:59:09
Or just use google translate, but there's clearly no uk supplier. So a proper hands on measuring up is going to be difficult.
;D should have got that from the url ::)
Aren't you're rear wheels almost the same size :-\ could use an old tyre for trial fitting...
265s would need a 35mm filler, a couple of 18mm chipboard panels cut to 650mm and screwed either side of the tyre gives you your 'tank' :y
