Author Topic: Lights out...  (Read 3326 times)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Lights out...
« on: 09 December 2013, 23:04:43 »
Literally  ;D...
Looks as if the right side bulb has blown this time round, Did this in the summer and a tap here and there and it came back to life... That didn't work this time  :(
Dash out job then by looks of it ::), Screws behind air vents/steering column if i remember correctly ?
The main beam light has always been dead, Never bothered me so never replaced, So now would be the chance to kill 2 with one stone, Well 3 birds with one stone if i decide to put the eml bulb back...
I'm sure Rob posted a link awhile ago to a place that sell these kind of bulbs somewhere, But i cant find it. Looking for good quality but also cheap  :y
No idea when i'' get round to doing this, Too cold and dark early these days  :-\ ... So i'm in no rush to do this as i can still see the part of the display not lit even in the pitch black, Just enough back light too see.
Re: Lights out...
« Reply #1 on: 09 December 2013, 23:06:25 »
Vauxhall or Factors, readily available cheaply enough :y
Shallow Al
  • Lymington, Hampshire.
    • 3.0 Litre Elite.
Re: Lights out...
« Reply #2 on: 10 December 2013, 00:17:18 »
The self same bulb has blown on mine. MOT is due in a day or two, will it pass with this?
You can see the speedo clear enough.
Cheers.
I used to know everything. Then I got married.
Re: Lights out...
« Reply #3 on: 10 December 2013, 00:21:00 »
Unlikely to be an MoT issue :-\
Re: Lights out...
« Reply #4 on: 10 December 2013, 12:28:56 »
Remember to get some spares, often others blow when you remove the dash  :y
Re: Lights out...
« Reply #5 on: 10 December 2013, 16:13:10 »
Or while the dash is out, replace them all and keep the old working bulbs as spares ;)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Lights out...
« Reply #6 on: 10 December 2013, 18:04:03 »
How many bulbs are there in total on the 3.2 elite dash and are they all the same type ?
Re: Lights out...
« Reply #7 on: 10 December 2013, 20:50:40 »
Lots and no, to answer both your questions at once :y
Re: Lights out...
« Reply #8 on: 10 December 2013, 21:01:53 »
Cheers.
Sure will  ;)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Lights out...
« Reply #9 on: 10 December 2013, 23:06:04 »
Won't be replacing them all then    :o ;D
Any good places online to buy, CBA explaining to the idiots around here what an Omega is all the time. Plus probably cheaper online  ???
Re: Lights out...
« Reply #10 on: 10 December 2013, 23:21:49 »
Whip the cluster from the desmond and you'll see what's what :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Lights out...
« Reply #11 on: 19 January 2014, 18:15:27 »
Will these do for the far right side back light and main beam and eml ?
http://www.autobulbsdirect.co.uk/R509TOR-BX8.5D-Panel-Bulb-12V-1W-Orange-Base.html
Re: Lights out...
« Reply #12 on: 19 January 2014, 18:24:21 »
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Lights out...
« Reply #13 on: 19 January 2014, 18:28:50 »
http://www.omegaowners.com/forum/index.php?topic=90644.0
Thanks Rob  :y :y
So the x4 Yellow ones are the back light bulbs..
That would be these ?
http://www.autobulbsdirect.co.uk/R509TMBE-Dashboard-Bulbs-12V-1.5W-Beige.html
... Also What are those x2 Green bulbs, Can't work out what they could be.
Re: Lights out...
« Reply #14 on: 19 January 2014, 18:57:18 »
Thanks Rob  :y :y
Yes.
No.
One is low fuel, other is ignition (battery)
Main bulbs pull out of the yellow base, same as sidelight bulbs (501 5W) but are 2 or 2.2W some places call them 510 capless
« Last Edit: 19 January 2014, 18:59:07 by RobG »
Page created in 0.03 seconds with 20 queries.
