Author Topic: Heater cold one side  (Read 4356 times)
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
« on: 14 December 2013, 10:03:04 »
Pretty sure I found a guide to this on here but can't seem to find it now.
Basicly blowing hot passenger side and cold drivers any help please.
Cheers Ian
PAULCDX
Re: Heater cold one side
« Reply #1 on: 14 December 2013, 10:06:34 »
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
« Reply #2 on: 14 December 2013, 13:13:08 »
Cheers Ian
Whereabouts are you Ian? Having just suffered the same issue, I'd be more than happy to help you out if your close by mate :y
AKA - Mr Bracket
plym ian
  • Plymouth, Devon
« Reply #3 on: 14 December 2013, 16:07:22 »
Cheers Ian
Plymouth Devon
blackviper90210
« Reply #4 on: 14 December 2013, 16:37:25 »
Cheers Ian
Plymouth Devon
Local then!  ;D ;D ;D
AKA - Mr Bracket
« Reply #5 on: 14 December 2013, 16:38:34 »
Cheers Ian
Did you resolve yours?
blackviper90210
« Reply #6 on: 14 December 2013, 16:43:55 »
Cheers Ian
I did mate. Being totally stupid, didn't realise that there were motors in both footwells. I checked the passenger footwell as per the guide and that was fine, didn't realise that there would of been one the other side. I assumed that the motor did both sides since there was no mention of drivers side, lol. Live and learn!
I fixed mine by screwing a small screw into the motors plastic arm, so that the arm coming down from above had a bigger "pin" to hold onto.
Only thing now is the heaters are still not that hot. Will do another matrix flush now I've resolved that initial problem!
AKA - Mr Bracket
PAULCDX
« Reply #7 on: 14 December 2013, 21:36:57 »
Dave let's go on another road trip ?  ;D  :y
blackviper90210
« Reply #8 on: 14 December 2013, 21:44:02 »
How's there's a thought :y
AKA - Mr Bracket
« Reply #9 on: 14 December 2013, 21:56:41 »
Cheers Ian
Was this for the blend flap? Got any pictures?
Suspect I have same problem with my 3.2, centre vents red hot on high. Side vents and rear are cool.
blackviper90210
« Reply #10 on: 14 December 2013, 22:05:21 »
Cheers Ian
Unfortunately I didn't take any pictures mate, sorry :-[
It does sound like you have the same problem, but both sides. All I did was unplug the motor undue the screws holding the motor in place and withdrew it. Used a self tapping screw and screwed it onto the raised nipple on the arm on the back of the motor. Make sure though that the arm coming down from above, the hole will go over the head of the screw!!
Works a treat now, although it's still not very hot heat coming through on any vents. It's warm, but not hot. HTH's :y
AKA - Mr Bracket
« Reply #11 on: 14 December 2013, 22:20:20 »
Thanks for that, can't visualise what you mean. Will need to get my head down there and take a look  :y
« Reply #12 on: 15 December 2013, 10:16:25 »
Both sides cold? Thats different to what you told me. You said just passenger side was cold?
« Reply #13 on: 15 December 2013, 10:46:49 »
Trying to remember now  :-[
Been a few weeks since I drove 3.2, only the centre dash vents got as hot as they should. Ie almost burn your hand
plym ian
  • Plymouth, Devon
« Reply #14 on: 17 December 2013, 13:37:31 »
Had a look at mine today and it was the arm came off the motor bit. Managed to clip arm back on and now I have heat on drivers side. Cheers guys oof saves the day(and a costly trip to dealers!)
