Author Topic: Diff fluid top-up  (Read 5393 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Diff fluid top-up
« Reply #15 on: 17 December 2013, 12:35:30 »
ps I assume putting LS gear oil (with the extra additives) is not a problem to go in to a non lsd diff?
Yes, no problem. :y
beautiful! cheers kev  :y :y
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #16 on: 17 December 2013, 12:36:51 »
ps any idea what diameter hose the gearbox breather is? going to go searching for it in a few minutes... if I recall its quite a think one isn't it?
RIP Paul Lovejoy
« Reply #17 on: 17 December 2013, 12:52:42 »
No its a thick one , you cant miss it  :D
Webby the Bear
  • Northampton
« Reply #18 on: 17 December 2013, 15:58:38 »
one trusts this is the gearbox breather? :)
RIP Paul Lovejoy
« Reply #19 on: 17 December 2013, 16:05:15 »
Yep. :y
Webby the Bear
  • Northampton
« Reply #20 on: 17 December 2013, 16:15:29 »
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #21 on: 17 December 2013, 17:11:35 »
that reminds me... i had to take the plenum off to locate the GB breather so i took the opportunity to clean the crankcase breathers. put it all back together and noticed that the two o rings from breather bridge to throttle body are leaking vacuum.... checked this with carb cleaner.
only replaced these a few months back and they've never been disturbed since. I'm wondering what your thoughts are on popping a layer of black cam cover sealant round it?
RIP Paul Lovejoy
« Reply #22 on: 17 December 2013, 19:44:46 »
You'll only have to clean it off when you fit a new O seal  ;) ;)
Webby the Bear
  • Northampton
« Reply #23 on: 17 December 2013, 19:54:59 »
Yeah I thought about that. but tbh it comes off in a big chunk so im not too worried about it.....its just I cant get to the dealer for a while and was thinking of this as a temp repair :)
RIP Paul Lovejoy
« Reply #24 on: 17 December 2013, 20:05:52 »
I've seen worse .....as long as you don't forget  ;)
Webby the Bear
  • Northampton
« Reply #25 on: 17 December 2013, 20:17:50 »
What would happen if I did forget... other than it leaking again?  :-\
RIP Paul Lovejoy
« Reply #26 on: 17 December 2013, 20:19:54 »
You'll have the OOF Bodge Boys turn up at your school ......  ;D ;D ;D
Nothing will happen, it'll probably last OK too  :y
Webby the Bear
  • Northampton
« Reply #27 on: 17 December 2013, 20:20:47 »
 ;D ;D ;D ;D Thanks Andy. Was just worried about bits of bendy plastic getting in't cylinders  :-[
RIP Paul Lovejoy
« Reply #28 on: 17 December 2013, 20:22:22 »
It'd burn off harmlessly if it did  ;)
Webby the Bear
  • Northampton
« Reply #29 on: 17 December 2013, 20:24:21 »
oooh goody :):):) cheers broseph  :y
RIP Paul Lovejoy
